08-22-2022, 07:37 PM | #1 |
Rep 8
Please help !! Dead battery (big problem)
Edit:vehicle is 2015 BMW X1 35i
Need help please !!! Battery died I swapped out the battery and it worked fine. Didn’t use the car for about 2 months and the battery died again. The car dash turns on as well as head unit. It will crank but won’t start. I get code 6293 missing fuel pump. I have checked the module and tried a new one with no fix. If you have any ideas please lmk. I have never had issues with sluggish fuel/throttle response or any warnings or codes with fuel pump before. I have checked ground(including under chasis) tested all fuses. When I was trying to start the car intermittently fuse 70 popped and I replaced it (hasn’t popped since) I have checked ibs and battery connection. I also registered the new battery via BimmerCode. Will post all error codes. Please help I have tried getting information via forums and google. Tried on my own for about a week straight. ERROR CODES Error memory Date: 8/19/22, 10:30 AM 00 Safety and information module (SIM) 1 error A739: PL2: CENTRAL LOCK, DRIVE TAILGATE 01 Safety and information module 12 Motor electronics 5 errors CDB7: OxCDB7 PT-CAN, message (Status Electric Fuel Pump, 0x335): missing 371A: 0x371A Valvetronic, supply voltage: line interruption 2DC6: 0x2DC6 Valvetronic, supply voltage: malfunction 2DB6: 0x2DB6 Valvetronic relay, control: line interruption 31E9: 0x31E9 Electric fan, control line: line interruption 17 Electronic fuel pump control module 1 error 6293: EKP engine: current too high 1 |
08-23-2022, 05:44 PM | #2 |
32
Rep 279
Sounds like battery problem. If you replaced battery and then didn't drive car it likely just discharged.
Did you register battery to car? Often parasitic discharge could cause low battery voltage especially if the new battery wasn't fully charged. |
08-24-2022, 06:47 AM | #3 |
2709
Rep 2,350
If the new battery was not fully charged after installation, most likely got discharged.
Try a trickle charger and leave it on and see what happens. It is also possible that the new battery could be a lemon to begin with. Who knows. The vehicle looses power in time but not to that extent. One month of non driving should deplete a max 20% of the battery (being dramatic). Or, you have something that really eats your power. try charging the battery. Noco 5 or a Ctek trickle charger is what you need. make sure you pick the righ battery (non-AGM) |
08-30-2022, 03:11 PM | #4 | |
Rep 8
08-30-2022, 03:13 PM | #5 |
Rep 8
also on a side not. before i coded the second battery. it showed an agm 80ah battery so thats why i went back to an agm battery. on the 3rd shot lol. i guess agm was the original battery at 80ah
08-31-2022, 02:05 PM | #7 |
Rep 23
I was getting occasional low battery warnings with a new battery and eventually the car wouldn't start necessitating a new starter and new engine ground strap.
09-01-2022, 03:19 PM | #8 | |
2709
Rep 2,350
My 2012 E84 had a regular non-AGM and the OEM replacement battery is also BMW non-AGM. They never die… Last edited by Teutonic; 09-01-2022 at 03:26 PM.. |
09-01-2022, 03:25 PM | #9 | |
2709
Rep 2,350
Please keep in mind that AGM batteries have an electronic module that will deem the battery as replaceable if drops under a certain voltage. An old style flooded battery non-AGm can be brought back to life if the components are ok. The new module controlled batteries will not allow that. Actualy, my original 2012 battery non-AGM was replaced in 2020 when there were no issues.I just thought it is a good idea to replace it because it was old. Regardless, the tester confirmed at that time thatthe battery was actually in perfect parameters, Amazing. I bought the same as a replacement. |
09-02-2022, 01:30 AM | #10 | |
Rep 8
im super confused as to what this can be. is there a schematic for power lines that i can find to see if the valvetronic and fuel pump are somehow connected somewhere or if i can follow a wires to see if maybe a rodent chewed it up ? edit : the car cranks. sounds like the starter is ticking and the engine wants to start but nothing. also found the schematic doesnt seem to have anything to do with fuel pump and valvetronic Last edited by louisf92; 09-02-2022 at 01:38 AM.. Reason: more info |
09-02-2022, 02:20 AM | #11 |
Rep 8
update i reset the codes (forgot to do that) checked for codes before trying to start and nothing. i try to start it again and the only code that pops up is the:
6293: ekp engine: current too high |
09-02-2022, 10:14 AM | #12 | |
2709
Rep 2,350
Sorry about your problem. Not sure what it can be. Why don’t you take it to a dealership or ask a tech to stop by to give you a hand? |
09-04-2022, 09:27 PM | #13 |
Rep 8
hi thanks for the suggestion, looks like i have a short of some kind.. fuse #70 (20A) keeps blowing whenever i try to start it. any ideas ? im gonna see if i can find it maybe
09-05-2022, 04:32 PM | #14 |
2709
Rep 2,350
One of E84 recalls was about the positive cable that runs from the battery tothe fuse box. It was major recall. Was that one done in your case?
Either way, go to a dealer. They have all the tools to help you out. Sometimes a little more expensive is cheaper. Ialways got o the dealership for evry little thing and my cars are running trouble free. |
09-05-2022, 04:35 PM | #15 |
2709
Rep 2,350
E70 is an engine related fuse. Not sure what though.
09-06-2022, 09:24 AM | #16 |
298
Rep 711
Hmm, I'm going to have to take a look at my battery again, I could have sworn it was AGM - 2015 X1 35i m-sport. I bought it CPO in 2017, so I'm fairly confident its battery is the original, as I haven't changed it.
09-06-2022, 09:26 AM | #17 |
298
Rep 711
Not sure if this is helpful or not, but the EKP is the controller for the low pressure fuel pump. Can you hear it prime at all right before starting your car? Not sure why sitting for 2 months idle would do anything to the EKP?
09-07-2022, 12:04 AM | #19 |
Rep 8
HUGE UPDATE !!! i measured power from the ekmp3 to make sure fuel pump was recieving power. (it was) so i hotwired the battery directly to the pump and it was running but super slow and the cables where getting hot. assuming this was the problem since it barely made any noise i purchased the (BMW Fuel Pump Assembly) and replaced it.(possible cause) the fuel pump at the bottom was really dark(not the tank) inside the pump maybe residue of failing pump or bad fuel from sitting so long. the car now turns on but it has a delayed crank (will crank maybe 2 times instead of just turning on as usual....... and i am down to only 1 code. new code is
( 2c3e ) "quantity control valve short circuit to earth" |
09-07-2022, 01:16 PM | #20 |
598
Rep 1,343
Is your ground strap in good shape? BMW's located in wintry region has a propensity of disintegrating ground strap due to exposure to moisture and salt.
09-07-2022, 10:10 PM | #21 | |
Rep 8
UPDATE: NEW CODES 2c3e quantity control valve , control short circuit to earth 377c engine cooling system reduced power operation: supply voltage low 2bc0 mixture control too lean |
