07-19-2022, 12:27 PM | #1 |
127
Rep 316
Tire/Wheel Widest Option for Track with KW DDC?
I want to upgrade my wheel setup on my comp pack, I have a track dedicated car but I want the F82 to take that spot. I am currently on KW DDC which is far from the best ideal track coilover but it will need to suffice for a season or two. They are from my understanding the same fitment as a KW V3, I plan to run camber front/rear, not sure the recommended numbers but I'm guessing -3F/-2R. I am worried about the perch more then anything. Recommendation please!!!!! I want the widest tire and wheel without having to cut anything.
07-19-2022, 02:54 PM | #2 |
151
Rep 133
You should be able to run 18x10 +25 with a 5mm spacer with 275/35. Ideally 275 is happier on an 18x10.5, but in your case you can get away with it! I wouldn't go higher than 275 on an 18x10 though.
This info all comes from Apex's figment guide which is awesome https://support.apexraceparts.com/hc...-Fitment-Guide They describe what's possible per suspension type.
IG - shaddyy
07-25-2022, 01:05 PM | #3 | |
127
Rep 316
07-26-2022, 01:22 PM | #4 |
Dont listen to me
795
Rep 562
295/30 is stretching too tight for inner clearance. See attached pictures of KW V3 versus an m437 rear wheel on the front (19x10 +40 offset) with a 20 mm spacer (so effective 10 inch wide wheel +20mm offset) and a 285/35 MP4S tire @ -2.0 degrees camber.
As you can see, there might be 5 mm of clearance between the tire and spring perch at that ride height and the outside edge of the tire rubs on the fender and fender liner. That ride height is too low anyway, so raising up the perch another half to one inch will buy you extra real estate on the inside, but you still need to clear the outside of the fender. That is where adding a lot of negative camber will come in. The wheel/tire to spring perch distance will not change by adding or removing camber since the wheel/tire/knuckle/coilover is basically one fixed assembly and moves as one. If you raised the car up by raising the spring perch up super high to clear the tire, plus adding a 10mm spacer up front, plus lots of negative camber to clear the outside fender, you might be able to squeeze a 295 tire up there, but at that point, you might be making a worse handling car just trying to fit a "fat tire" up front. That is why you see a lot of guys running skinny diameter 5" spring coilover setups with 18" wheels to keep the lower spring perch above the tire so they can maximize tire width while keeping stock front fenders. |
mitch32126.50 |
12-03-2022, 11:46 AM | #5 | ||
127
Rep 316
12-03-2022, 12:00 PM | #6 |
Dont listen to me
795
Rep 562
a 285/35-19 tire on the front rubs the hell out of the fender liner in several spots. You really need a 30 profile tire when going 285mm or wider tire up front. My 265/35-19 tire rubs the front fender liner enough to where I would consider it the 'maximum allowable rub' before you really start destroying and chewing holes all the way through the plastic liner.
12-03-2022, 12:12 PM | #7 | ||
127
Rep 316
