07-17-2022, 02:20 PM | #1 |
50
Rep 507
Track brake pads (pfc08 vs pfc 11 vs ds1.11)
Trying to find brake pads for track. I have stock calipers and stock rotors. Wanting to find one that is not too hard on rotors, have a long endurance life, and strong initial bite. Which is the best option among pfc08 vs pfc11 vs ds1.11? Open to other suggestions as well.
Also, do I need to do bedding every time I switch between street and track pads? Last edited by polarbearz; 07-17-2022 at 03:16 PM.. |
07-17-2022, 09:19 PM | #5 |
1093
Rep 920
I've had success with the DS3.12. It's got so much initial bite.
Personally, people overthink bedding IMO. I just put those pads in and drive. |
melanthius255.00 |
07-18-2022, 01:53 PM | #6 | |
IG: @panda_exprs
117
Rep 138
I "upgraded" from PFC08s which I didn't like because of not having enough max braking force and MOT, but the wear of which was outstanding (other than one front pad out of 4 that delaminated from the backing plate with still almost 1/4" of material thickness left, and therefore became garbage before it was actually worn out). Yeah, the DS3.12s provide stronger braking than the 08s, but I would think a substantially cheaper pad like the Hawk DTC-70 might be similar or be better than the 3.12s (I do know Hawks wear fast too). NYG, do you think I'll be happy with the PFC11s (i.e., are they capable of roughly the same mu and MOT as the 3.12s)? Maybe they'll last a bit longer than the Ferodos too, under the same heavy car/high-heat conditions?
PM ME FOR USED F8x PARTS! What's left: brand-new pair of VNE front brake rotors; used Ferodo DS3.12 and PFC08 front track pads and used Stoptech Sport and OEM rear brake pads; Apex wheel black center caps (brand new, never used) qty 3
MEDIA: @panda_exprs youtube.com/user/EGbeater/videos |
07-18-2022, 06:23 PM | #7 | |
10743
Rep 3,690
I was very happy with the performance of PFC11s. I actually liked the PFC08 a little more in the front. I felt like as the sessions went on, the 08 dealt with heat a little better. I never had pads that lasted like PFCs did - it was outrageous. I ended up trying Hawk pads because PFC wasn't available for my R8 and I'm 100% converted. You heard correctly about the wear but given their price point, they're still by my favorite pads so far. I run DTC60 combo - started with DTC70 front, 60 rear but my stock suspension is too soft for 70. A bit soft for 60 too but more manageable. |
sly1types431.50 |
07-19-2022, 08:22 AM | #8 |
576
Rep 684
I have been running PFC08s for the last four years. I found them to be the most economical, highly performing solutions. I tried the Hawk 60s which didn't last as long and PFC11s which I loved, but wore them out in one weekend at the Glen. For me, there is no better product than the 08s when using stock calipers.
EGbeater116.50 |
07-19-2022, 09:34 AM | #10 | |
10743
Rep 3,690
My only complaint with PFC was how poorly they package them and how often I got pads with chips and chunks that were broken off. |
EGbeater116.50 |
07-19-2022, 05:33 PM | #12 |
///M Powered for Life
11490
Rep 10,329
If you're running stock brake distribution, generally use the same pad front and rear.
07-19-2022, 05:52 PM | #13 | |
IG: @panda_exprs
117
Rep 138
If the PFC11s only lasted you "one weekend" at Watkins Glen (is that one day or two days, and how many sessions per day, and roughly how long each session?), how many weekends/days/sessions do the PFC08s last you?
07-20-2022, 06:35 AM | #15 | ||
576
Rep 684
PS: the Glen event was a three day weekend and I recall there being a few delays due to rain - so technically I probably only ran 9-10 sessions. |
07-20-2022, 06:37 AM | #16 |
576
Rep 684
SYT_Shadow11490.00 |
07-20-2022, 09:29 AM | #17 |
10743
Rep 3,690
PFC11s bite harder and faster but I found them to drop off as you pump more heat into the system. PFC08 stayed more consistent and although they didn't bite quite as hard, it made me more confident in my braking which I spent a lot of time looking for with the stock setup until I went with the BBK.
I would agree on this for the most part but I had really good experience with PFC08 front and PFC11 rear on the stock calipers. It felt like the bias shifted to the rear a little and I was working my front brakes a bit less. |
