Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      06-15-2022, 02:29 PM   #1
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
Thumbs up Impressions: CCB calipers + Girodisc rotors + Girodisc GP40/20 pads
Posted here as well in the GTMore thread, but here it'll have more visibility.
We've been running GTS1 with the stock CCB calipers and Girodisc rotors. We've run two different pad setups: RSL29 and GP40/20. It's a good idea to share the performance with the rest of the M world, so here goes:
Rotors:
Walking around a paddock you see plenty of cars running Girodisc rotors. Pretty much any fast car that comes from the factory with CCBs swaps to the Girodisc setup.
This generally tells you that Girodisc is the real deal, but we weren't 100% sure until we tried them for ourselves. Well, they are definitely the real deal, they've taken 12 days so far and are probably at 50% wear.
The Girodisc themselves are huge (400mm front, 380mm rear) and very heavy, however, like we found with the 36mm thick BW-Alcon BBKs, the extra mass makes a big difference in longevity and keeping temps in check
Backing plates:
Out of an abundance of caution, we bought Ti backing plates for the calipers. On our F80 CS we torched the rear dust boots the one time we used the stock rear brakes and don't want this to happen to the CCB calipers. We got the front shims from ebay and the rears from Girodisc
Pads:
Overall, a downside to running the Girodiscs is PFC does not make a pad for it. We have been thoroughly spoiled by many PFC pads and were not looking forward to something different. In the end we tried two different pads.
Pad compound 1: RSL29
The shortest comment is they feel like someone has stolen your brake pads and replaced them for pieces of wood. There is little to no feedback from the brakes running this pad. They do last a long time, but otherwise there's no lost love for this pad and hopefully we will never run it again.
Pad compound 2: Girodisc GP40/20
We had never heard of these, but ran into them when getting the Ti shims. Given the good experience with the rotors, what about their pads?
We were pleasantly surprised with their good performance. Good pedal feel and threshold feedback which is really important. As a side bonus, they aren't loud on the street once bedded in and don't wear quickly.
We can finally dispel the myth that 'no BMW comes with good track brakes'. These are clearly very good, and have the same track mods that any other brand of cars has for serious track work (rotors and pads). The two 991.2 GT3 RS we were chasing in a recent weekend were using AP Racing on one and PFC (cup car brake conversion, $$$$$$) on the other. So it seems like not only BMWs get upgraded brakes...
That said, we have had our nickel plated BimmerWorld-Alcon BBKs on order since Jan and they should be arriving soon, so it is likely we will not test any other pads/setups on the stock calipers.
We look forward to running 18" wheel setups and the latest PFC pads
Let's look at some pics of this setup
The pads are shiny silver colored. Also take a look at the Ti shims. The front pads are absolutely massive
Installed
Appreciate 5
Wanted_M759.00
CSBM52722.50
David0ff1059.00
      06-16-2022, 12:52 AM   #2
SilleM3
SilleM3's Avatar
Drives: 2018 bl Saphire competition M3
Great review. How's the initial bite, modulation on track, and noise on the street? Are the brakes daily drivable?
      06-16-2022, 06:42 AM   #3
SYT_Shadow
SYT_Shadow's Avatar
11490
I've always dailied my track pads, even if that means sounding like a garbage truck every time I spot.
The GP40/20 is pretty quiet on the street once bedded in. If I used this car year round, I'd use the track pads for summer/track season and swap to a street pad for the rest of the year
Modulation was significantly better than the rsl29
To put it another way, we have been spoiled for many years with top shelf BBKs, and using the OEM CCB setup + giro rotors, the system worked well and is more capable than needed for serious track work. We won't have video ready to be uploaded for a while, but we were consistently outbraking one of the fast Cup cars despite weighing +1000lb more
      06-21-2022, 06:49 PM   #4
alpinefd
Drives: M3 F80
for those of you who doesn't street drive your cars, how do you bed in the brake pad at the track?
      06-22-2022, 07:12 PM   #5
markw10702
119
Drives: GTMore Anyone?
Usually you would use the first session to bed the pads. This is somewhat problematic as 1) it shortens your session, 2) if there are lots of cars in your run group you'll be a moving chicane.
I have been using Cobalt Friction pads. Great product and unlike some pads which require a complicated process the Cobalts bed really quickly. Usually by the time you get to the track they are ready to go.
      06-22-2022, 10:00 PM   #6
SYT_Shadow
SYT_Shadow's Avatar
11490
Some pads, like PFCs, are 'arrive and drive' and don't need any special procedure
If you do have to bed them, you can try to do it in the first two laps where people are usually warming their tires up
      06-24-2022, 11:15 PM   #7
sc_tr0jan_m3
sc_tr0jan_m3's Avatar
519
Drives: 2018 Grigio Telesto F80 M3 DCT
You don't need a full session to bed pads. It should take no more than 2 laps, if that…
2018 Grigio Telesto F80 M3 DCT | :: Bone Stock ::
2004 Titanium Silver E46 M3 6 Speed | :: Track Car ::
      06-28-2022, 10:22 AM   #8
alpinefd
Drives: M3 F80
I guess the issue with bedding in pads using the on track session is the possible brake fade and also how do you cool down the brakes after break in.
      06-28-2022, 12:19 PM   #9
FrankMstein
FrankMstein's Avatar
Drives: F80 M3, R56 Camden, G37x
Had you considered Pagid RSC1?
      06-28-2022, 12:28 PM   #10
SYT_Shadow
SYT_Shadow's Avatar
11490
Very briefly.
If with the regular pads the CCBs lasted a few weekends, I don't see how RSC1 would provide a large enough improvement.
CCB rotor replacement cost is so high that they'd have to last 10x as much as iron rotors. Currently, CCB rotors and OEM pads last ~half of an iron rotor, so it's off by an order of magnitude
f80post
