04-13-2022, 02:31 PM | #1 |
1020
Rep 910
Who has actually tracked CCB rotors?
Who has tracked them and taken them to the weight limit and beyond, got them hot?!? What happened to them?
Cars like the P GT3RS has CCB and people track them... I understand why BW and Turner say they are not made for the track BUT they also want to sell you steel and pads... I understand exactly what happens to the rotors and pads when they get hot. I just want to hear from someone who had taken them to the limit, first hand. |
04-13-2022, 03:08 PM | #2 |
10743
Rep 3,690
When they get hot (and they get really hot) it starts to oxidize. You'll get these craters all over the surface starting to form in as little as 2 track days. Especially worse with the weak stock brake cooling on the F8x.
You essentially ruin the rotors in a few track days and their replacement cost is ridiculous. I don't think CCB feels as good as iron either. |
SilverLakeM3241.00 |
04-13-2022, 03:28 PM | #3 |
///M Powered for Life
11490
Rep 10,329
You 'can' track them.
The P GT3 and GT3 RS have optional CCBs, which no one who tracks uses. If you see them mounted then for sure the driver is not fast. Most of the time they are not fast anyway, but are still smart enough to not use their CCBs and they do an iron conversion kit from Girodisc and call it a day. They wear faster than a set of BBK rotors if you get them really hot. If you are just putting around then the CCBs never get hot enough to oxidize and they work just fine. Using a track pad formulated for a CCB helps them last longer, the Pagid RSC pads for example. There's a nice video from BimmerWorld comparing the CCBs to the CCB+RSC to a Girodisc conversion Edit: I have tracked CCBs pretty extensively, or at least as extensively as they can be tracked until they were burnt out and we swapped to M2C rotors. Driven hard, they last less than a normal set of BBK rotors. What a waste! Incredibly expensive mistake. On GTS1 and GTS2, the CCBs went straight off both cars and will go onto our E90 and E92 street cars, where they will serve the true purpose of CCBs: looking pretty behind big wheels.
04-13-2022, 04:35 PM | #5 |
4999
Rep 4,139
lol wtf, whats the point of the CCB if not for the track?
04-13-2022, 06:44 PM | #6 |
2181
Rep 1,664
My GT4 has PCCB's, I run Girodiscs because of the aforementioned cost to track. If they weren't so extortionate, I would 100pc run them all the time. The reduced unsprung weight has a magical effect on suspension, the feel is incredible. The suspension responds way quicker and more delicately. For a street car they are a no brainer as you will never wear them out and the performance is great.
If you do have ceramics and run them on track, don't let the pads get below 50pc life as this will help extend the longevity and reduce heat build up on the discs. Most CC discs are made by Brembo so it's all the same stuff. |
04-13-2022, 07:18 PM | #7 |
1020
Rep 910
Yep, if the pad gets past 50% it is unable to absorb and dissipate the heat as well and becomes overheated and will wear exponentially. Similarly, but not the same, as conventional pads. I will be getting Ti or SS shims ASA I can get the pads traced/drawn.
With all the CCB sets here from conversions I was tossing around the option of just cycling through used sets as that is possibly more cost effective depending on the price of the used sets. However you CAN get the Girodisks without the hat and then the Giros are the cheaper option. CC pads are the similar price as Pagid RSL29's. For the record PFC makes the CCB rear shape in their 08 compound and waiting on tooling for the front...some day. STILL waiting on the steel conversion disks that have been in the works for 3-4 years FFS. |
04-13-2022, 07:32 PM | #8 |
241
Rep 510
I appreciate the information here. Was not aware of replacing the pads when less than 50%. Will have to check mine out. I know the rotor wear is measured by weight and a visual inspection but for the pads, is it a width measurement or weight?
NYG10742.50 |
04-13-2022, 07:52 PM | #9 | |
2181
Rep 1,664
https://www.screeningeagle.com/en/products/carboteq Weighing as it not that accurate AFAIK, but could be wrong. Pads are just like any pad, you can inspect it visually for remaining thickness. |
FrankMstein1019.50 JLS_397K126.00 |
04-13-2022, 08:13 PM | #10 | |
1549
Rep 3,788
https://f80.bimmerpost.com/forums/sh....php?t=1239580
04-13-2022, 08:23 PM | #11 |
241
Rep 510
Would it be reasonable to replace just the front discs and pads for trackdays and leaving the rears alone?
I'm thinking if this works then it's a cost effective option for trackdays. |
04-13-2022, 08:36 PM | #12 | |
1549
Rep 3,788
CCBs are best for street/daily/spirited driving duties. |
NYG10742.50 SYT_Shadow11490.00 |
04-13-2022, 08:36 PM | #13 | |
1020
Rep 910
04-13-2022, 08:39 PM | #14 | |
241
Rep 510
Shame that FCP doesn't sell carbon ceramics. |
D_SheerDrivingPleasure1094.00 |
04-13-2022, 08:44 PM | #15 |
1020
Rep 910
I had considered that seeing as how a friend tracked his and the rears never not that hot. He ran with traction control off of course.
04-13-2022, 08:48 PM | #16 | |
1549
Rep 3,788
Yes, the best way is to just pick up a complete set of Girodiscs and pads, if tracking is a must. Swap between the CCB and Iron and that is really the best and only way. Unless you keep the Girodiscs on permanently and just swap out track and street pads. That's what I'm doing... I have CCB Calipers and Girodiscs paired with a Private Label Street/Track Pads and Spiegler Lines and good fluid. I don't ever get around to getting to the track but this setup works well for my needs. I get the Gold CCB bling behind my wheels and additional/superior stopping power and cooling. Only thing I'm missing out on is the CCB Discs weight savings, but I think my FI-Rs make up for it. Good compromise. Shameless plug... I have 2 complete sets of Girodiscs for sale if anyone is interested. One set is brand new in box and the other set was lightly used. |
04-13-2022, 08:52 PM | #17 | |
1549
Rep 3,788
Girodiscs are the way to go, if you want OEM 6/4pot track capable calipers. Not to say the 4/2pot are not track capable. With good pads, fluid and lines... I've heard they get the job done as well. Otherwise, just go AP/Essex. |
04-13-2022, 08:57 PM | #18 | |
1020
Rep 910
04-13-2022, 09:05 PM | #19 |
1549
Rep 3,788
04-13-2022, 09:20 PM | #22 | |
1549
Rep 3,788
Ask any true track enthusiasts, especially the P car drivers what they use to track their cars and save the costly CCBs. Yasssss! |
