04-04-2022, 08:58 PM | #2 |
273
Rep 298
On my car i cant tell what it connects to. it appears to go down between the plastic wheel well and the headlight. I am guessing it might be for the adaptive headlight sensor or power wire for the headlight washer motor. when i remove the fan to replace my idler pully and belts i'll try and see if that gives more room to see further down to what it connects to. good luck.
04-05-2022, 08:55 PM | #4 |
293
Rep 360
That whole area has been messed with. Is the cloth tape just falling off closer to the center of the car?
To help answer your question, I'd peal back the electrical tape and see what colors the wires are. I'd honestly pull that wrap off to see what is going on there. Maybe someone tapped something to connect something and then uninstalled it and cut the wire? In that case maybe those wires aren't needed. Maybe they did cut factory wires going to something? It's kind of hard to tell. Do you have any error messages or codes?
Current:
2017 F87 M2 6MT 2013 F25 X3 3.5i 2008 E90 M3 6MT |
04-06-2022, 12:12 PM | #5 | |
8
Rep 240
