04-01-2022, 12:27 PM | #1 |
10744
Rep 3,690
Any of you guys have good experience with Girodisc rotors?
I'm going to finish installing the front Girodisc rotors onto my R8 today - aside from them being half the price of a replacement set of factory rotors; are you happy with their performance? It's an upgrade in overall diameter for me (36*-380mm) but same caliper + pads.
I've had no significant temperature issues with the factory rotors as far as overheating brake fluids but I notice the lack of bite as they get hotter. Should I expect some improvement? |
04-01-2022, 12:36 PM | #2 |
///M Powered for Life
11490
Rep 10,329
They are absolutely top notch.
I knew they were somewhat good because I've only heard good things about them over the years, but I ran them last year on the GTS and was really impressed. Top notch metallurgy, after 7 days they still look great -- more than the BBK you used to run for example. As a PFC and Alcon-BimmerWorld BBK user I thought it was not possible to be positively surprised with a rotor kit, but the Giro delivered. Get the biggest diameter you can swing if they have options. There is a large difference between high quality aftermarket two piece rotors and oem-anything when talking about track use. Cooling is significantly better in a high quality aftermarket rotor like the PFC DD (NLA) and the Girodisc Edit: I am still switching from CCB calipers+Girodisc to a set of nickel plated Alcon-BimmerWorld BBK, but this has more to do with running 18" wheels than anything else. For the first part of the 2022 season I'll run CCB calipers+Girodisc in GTS1 and PFC front BBK+AP RadiCal rear BBK in GTS2. Once the nickel ones are ready both cars will swap out |
NYG10744.00 FrankMstein1019.50 |
04-01-2022, 12:40 PM | #3 | |
10744
Rep 3,690
This was the largest diameter - have to run a 7mm spacer between the knuckle and caliper. |
SYT_Shadow11490.00 |
04-01-2022, 12:54 PM | #5 |
10744
Rep 3,690
Their surface finish is really nice too. If only PFC made pads for my car.
SYT_Shadow11490.00 D_SheerDrivingPleasure1094.00 |
04-01-2022, 01:54 PM | #7 |
2182
Rep 1,665
This is my front rotor after about around 14 days give or take, they wear pretty well I think. Some slight cracking from heat cycles. I think they are a very good upgrade across basically every marque of car because the discs are much better than any OEM is making.
NYG10744.00 SYT_Shadow11490.00 |
04-01-2022, 11:02 PM | #8 |
63
Rep 119
Best setup in my opinion
My setup includes Goodridge SS lines and Akebono ceramic pads |
04-02-2022, 06:02 PM | #9 |
371
Rep 280
Really liked them. Pedal never went even a little soft for a full 25 min session with Girodiscs (fronts only in my case), Castrol SRF and PFC11 pads. Very good upgrade over OEM rotors. Highly recommend!
[SOLD] 2020 ///M4 CS
NYG10744.00 |
04-02-2022, 08:43 PM | #10 |
10744
Rep 3,690
04-03-2022, 12:01 AM | #11 |
172
Rep 392
04-03-2022, 08:32 AM | #12 |
371
Rep 280
Dealership gave me an offer I couldn’t refuse. No replacement yet. Hate the new //Ms. The track day itch is killing me.
04-03-2022, 01:57 PM | #13 |
10744
Rep 3,690
04-03-2022, 01:59 PM | #14 |
10744
Rep 3,690
It's really hard for me to admit but as time goes on I'm starting to really like the new G8x more... not in all colors but black looks really mean.
04-03-2022, 03:15 PM | #15 |
172
Rep 392
04-03-2022, 07:40 PM | #16 |
10744
Rep 3,690
04-04-2022, 12:10 PM | #17 |
172
Rep 392
04-04-2022, 12:14 PM | #18 | |
10744
Rep 3,690
First time about their performance? Hawks are outstanding! I liked Ferodo but can no longer justify their price and how quickly they disintegrate. |
04-04-2022, 12:19 PM | #19 | |
1020
Rep 910
NYG10744.00 |
04-04-2022, 12:23 PM | #20 |
1020
Rep 910
FWIW PFC does make a pad to fit only the rear (not front YET) CCB caliper (FMSI 1155) PFC 7780 but you can only get it in 08 compound with 18mm thickness and min qty is 50 sets. The tool is on the way, pads ~1 year away. Rotors, been 3 years in the making and some day...
NYG10744.00 |
04-04-2022, 12:41 PM | #21 |
11490
Rep 10,329
They'll be for sale in June once the Alcons are ready. Until then they need to work hard on GTS1!!
