03-17-2022, 12:06 AM | #1 |
47
Rep 80
Scared to buy X5M...is it a maintenance nightmare?
I'm about to buy a 2012 x5M with 49k miles. Well serviced and injectors already upgraded. But i keep reading about lots of issues, hoses,vacuums, lines, leaks....I'm getting confused, last thing I want is to buy a car that goes on limp mode every 2 weeks for different problems. Can someone give me a proper list of every part i need to make sure this thing is reliable please? I work on it myself with a mechanic friend, so i just need to buy all those commonly failing parts like hoses, vacuum lines, PCV. I read so many threads my head explode. Please help so i can finally get this machine....
03-17-2022, 03:12 AM | #2 | |
1416
Rep 1,564
Preventative Maintence you should do now, not so much of the miles but because of the age: Replace all of your plugs and coils. Upgrade to NGK if you plan on tuning, otherwise get the OEM Bosch plugs and save the M tax. Eldor brand coils are the best for our platform. Replace the Head to Head coolant line and upgrade the plastic Y junction to metal. Replace the Plastic T's in the turbo coolant lines with Metal (Some M's have metal already) Replace all of your CCV lines, especially lines that connect to your lower intakes. Inspect all of your vacuum lines, including the ones that run back to the muffler flaps. If any of them appear to be drying out, replace them all with silicone lines. Change your transmission, rear diff, front diff, and transfer case oils. Even though you have low mileage, the oil is a decade old and should be changed (assuming previous owner has not touched. Change your Engine Coolant and Intercooler coolant if it has not been done yet. Note that there are special bleed procedures on both explained in BMW TIS Inspect Power steering fluid and change if needed. Realoem.com is the best place to look up parts and their oem Equivalents. If you don't have BMW TIS, PM one of us here to get setup. You will need this if you plan on doing the work yourself. Download and install ISTA or buy prebuilt laptop off ebay and get a D-CAN cable. Protools is second choice and Foxwell NT510 or higher is 3rd choice. You will need one of these to do basic service functions. Highly recommend ISTA or Protools. ISTA is pain in ass to install and use but most powerful and is full diagnostic suite for the E70. You Should be good until around 100-120k+. Then expect increased oil usage and need to do valve stem seals. Last edited by Sophisticated Redneck; 03-17-2022 at 03:20 AM.. |
03-17-2022, 08:08 AM | #3 | |
47
Rep 80
TTV8M125.00 |
03-17-2022, 09:31 AM | #4 |
2022 M4 Comp Xdrive
1019
Rep 1,538
Only thing to add ontop what SophisticatedRedNeck mentioned is to install a lower temp thermostat. I know of two units that can be used, the Hamburg 95C or the N63intake.com 's 84C. I'm using the latter.
It's a really good upgrade to lower overall temps under the hood, keeps your turbos cooler, it will lower your oil temps also. Lower oil temps vs what the stock system runs it as will also degrade your oil much less than what it currently does with the stock thermostat. |
03-17-2022, 12:19 PM | #5 |
107
Rep 994
Not M specific, but BMW in general, hardparts are expensive.
A new transfer case was $4k from BMW, I bought a reman for $1.9k. aprox 115k miles on it before it failed. My front diff is leaking from somewhere. I had to replace the oilpan gasket, that is no small job, over $1k in parts and labor. Just keep in mind yes there are maintenance items, and replacing of "soft," parts like hoses and plastic bits. But getting in age the hardparts... are expensive and the labor to go with many of them. |
03-18-2022, 06:54 PM | #6 |
307
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
I’m averaging $450 a month in repairs out of pocket for my x5m and I have an extended warranty. The rest was covered by the warranty. I drive about 7k miles a year and it’s not my daily. 1st warranty covered 30k in repairs. 2nd about 6k.
Mine has needed a bit of work over the last 5+ years of ownership Both valve cover gaskets and passenger side 2x Alternator Rear air bags Engine partition 2x Turbo coolant lines Turbo oil lines 2x Turbo oil return block Rear main seal 2x common problem Filtered air ducts 2x Entire pcv system 2x Upper and lower oil pans Aux turbo coolant pump Coolant res Pneumatic pressure converters All map sensors Diverter valves Etml pump 2x All vacuum lines (2k job) Battery 2x Ac evaporator core (removed entire dash) Power steering pump New engine computer New rear shocks at 60k miles could be maintenance Replaced exhaust change over valve Front tension struts blown bushing Front lower control arms I’m sure I’m missing a bunch, and a lot I did myself or it was covered by my extended warranty Approximately 45k worth of work. This doesn’t touch maintenance, just what I consider repairs. Tons here, brakes are very expensive. I’ve been religious on oil changes, diff, xfer, tranny, power steering and coolant. I fix anything immediately that breaks. So yes if you want to keep it in good shape, and are not a mechanic it’s an expensive machine to keep on the road. I’ve spent 6k chasing my reduced engine power mode in 3 months, All new vacuum lines, new intake duct, between turbos and intercooler, new engine computer. Dealer and Indy to figure it out. So it can be expensive but it’s not too much money if you love it. Also it’s a choice between depreciation and repairs. The s63 is more reliable than the n63 and a good choice. Last edited by Thecastle; 03-18-2022 at 07:17 PM.. |
03-19-2022, 09:52 AM | #8 | |
Rep 34
03-19-2022, 06:02 PM | #9 | |
307
Rep 1,146
Drives: F10 550i
I’ve changed the oil, every 5k miles, coolant every 2 years, diffs, xfer case, tans fluid, and power steering flushes. Batteries, tires, wiper blades and etc. Done ceratec at each change, low temp thermostat at 45k miles, turbo blanket and etc. a lot of it is the climate. Bmws plastic turns to crap in hot weather climates. Really not unusual any of these repairs for an x5m if you search. I’ve just owned mine a lot longer than most here. Last edited by Thecastle; 03-19-2022 at 06:18 PM.. |
03-19-2022, 07:25 PM | #10 |
131
Rep 310
Mine is at 140K, and I will agree with S.R. for sure, and luckily I bought mine with low temp thermostats already in before 90k, but have gone through all of the pcv lines, the center one needs a better fix plus heat wrap, I still haven't found the best solution.
Castle also highlights a lot of big points, especially if you want it perfect. Say partitions, I bought the chinese ones and then heat taped them, not perfect but they work. All of the cheap plastic, and super high heat, means stuff breaks and leaks. I work on mine so its not a big deal, and I can get parts fast so I dont need to stock them up, like you might. And guess what, I watch my oil, so a leak isnt a cause for a 5K gasket job for me, unless it's fast enough to need oil in under 1000 miles. My suspension, I did sway bar links up front, rear bags had been done when i bought it, but other than a possible need for new tension struts or at least bushings up front, pretty solid. In conclusion, if you do work yourself, and can get parts it's worth it, if you are paying maintenance to a shop, nope. These rigs are beasts that need an attentive and handy owner after the first 5/50k IMO. |
03-20-2022, 09:20 AM | #11 | |
47
Rep 80
03-20-2022, 03:09 PM | #12 |
47
Rep 80
Question...
Is the f85 x5M more reliable than the e70 ? I could buy an f85 instead, same mileage,about 45k, . I don't mind to spend the extra money of i don't get the headache of the problems and repairs. So considering mileage is the same on both, is it worth spending that much more money or even worth the f85 I'm gonna spend thousands on parts and problems same way? |
03-20-2022, 03:47 PM | #13 | |
307
Rep 1,146
Drives: F10 550i
I'm going to express an opinion that some will surely disagree with. I think the E70 was built during a low point in BMW reliability (mid-00's). I think G05/F15/F85 are more reliable based on my ownership experience of an F10 and my friends experience with theirs (small sample). BMW has really worked hard to improve the quality of their cars, and I think the G05 with the Gen 3 V8 N/S63TU3 has addressed all the heat damage concerns. But yes I think an F85 because its newer, and BMW made a concerted effort to address many of the E70 concerns, you'll likely have better luck with it. But remember, these are essentially very expensive "sports" SUVs, and will always be more expensive to maintain than a regular X5. You pay in depreciation or repairs.. There is a class action lawsuit and settlement against the N/S63TU as well. While I've had 0 problems with my N63TU, it seems that a lot of people have continued to have problems, especially with oil consumption on the N63TU. My 550i (F10) has 81K miles and been flawless. Though I put a low temp t-stat on that one too (every v8 I've owned from BMW I've done this mod). Its my 3rd v8 from BMW. Neither my S63 or N63TU have ever burned any detectable amount of oil. Leaks that's a different matter. These cars are best owned under an extended warranty or if you like to DIY/know a mechanic. I used to do all of my own work, but owning multiple businesses, an extended warranty has been a time saver for the work I don't want to do. Much of the work I had done above was covered by my extended warranties (2x) on the X5M. Mine is currently under warranty until 2025. |
03-20-2022, 03:58 PM | #14 | |
307
Rep 1,146
Drives: F10 550i
Jeeps are known for blowing xfer cases. Bad lifters Oil consumption The BMW is faster.... |
03-20-2022, 07:50 PM | #15 |
47
Rep 80
Anyone knows for sure if bmw fixed many of the problems from e70 to f85? My main issue is the time consuming effort of fixing things continuously, i don't mind maintenance and fixing problems, i just would like to drive and enjoy without that dreaded engine malfunction light popping up every other week. If the f85 addressed those issues i don't mind to spend an extra 30k for it. I been on this forum researching for a whole week on the e70 x5m, and it's my conclusions that most people have lots of problems and downtime with it .
03-21-2022, 01:36 AM | #16 | |
1416
Rep 1,564
My recommendation to you is to choose a low Mileage M that was driven very little in city traffic. Heat is what causes all of the issues with these rigs. All of the issues are about plastic and rubber bits failing or sensors going out, all related to heat. Something in the 30-60K mileage would be ideal and from an owner that did mainly highway miles and very little city/stop and go. This is why you find such a variation with the experiences, with some reporting no issues, and others a nightmare. A M that was used for city commutes in stop and go traffic or left idling in the summer heat while waiting for the kids will be a nightmare later in its life with all the sensors and plastic/rubber failing, vs the M that was driven fast on a highway which will have little issues even thought technically its engine was pushed harder. Knowing the previous owners driving habits is just as important as the service records which choosing one. As for Jeep vs M, I would test drive them both and see which one you like better, it is two completely different experiences. There is a reason why we put up with such complicated machines, nothing else comes close to driving like them IMHO. Last edited by Sophisticated Redneck; 03-21-2022 at 01:55 AM.. |
03-21-2022, 01:29 PM | #18 |
307
Rep 1,146
Drives: F10 550i
I'd also mention there are some advantages of an E70 over an F85.
The E70 has hydraulic steering which give much better road and steering feel than an F85. Its more depreciated so it will be cheaper on initial purchase. The E70's problems due to age are well known and you'll find plenty of after market support and parts to fix these issues. I like both the F85 and E70, but if I was shopping I'd choose an F85. The Jeep doesn't have as much power, nor does it have the hydraulic role stabilization which makes the E70/F85 have very little body roll. I would go newer rather than older there as well. But its ultimately about what you like driving day in and day out. |
03-21-2022, 07:05 PM | #19 |
47
Rep 80
Well i don't make up my mind yet, but it's gonna be either the e70 or the f85.....i can't decide. On one side i save 30k getting the e70 that i equally like, but I'm thinking about the stress and money if I'm not a lucky one..... second I'm scared to spend the extra 30k and then start having the same issues as if i bought the e70. Coincidentally they both have 44k miles on them.....
03-21-2022, 10:43 PM | #20 | |
1416
Rep 1,564
To might want to drive both first, E70 and F85 feel quite a bit different, with pros and cons for each. |
03-22-2022, 09:07 AM | #21 | |
47
Rep 80
03-23-2022, 08:49 PM | #22 |
Rep 7
Drives: 2013 BMW X5 M
Wow. This thread is exactly what I needed. New member here. Purchased my '13 X5 M with 107k miles on it a few weeks ago.
Coming from a Jeep that's old enough to drink to my first Bimmer, I'm in love but also terrified. I'm a DIY mechanic and not afraid of doing my own maintenance and repairs, but I know I'm lacking a lot of knowledge! ...and BMW TIS I just changed the oil with Castrol Edge 5w30 and tightened up the oil pump chain tension per Sophisticated Redneck's "Something every X5M and 50i owner should check." thread. Mine looked exactly like that video so I'm glad I did! Looks like my to-do list just got significantly longer. |
