01-06-2022, 03:04 PM | #1 |
1020
Rep 910
Input on road course telemetry app for iPhone
Looking to get back into track driving this year. What apps do you all use? I would like to record video and times. I haven't researched too far. Harrys/Petrol, TrackAddict, RaceChrono...? Advantages/dissadvantages?
01-06-2022, 04:57 PM | #2 |
57
Rep 145
I use a combination of Harry's Laptimer, a 10Hz External GPS and a GoPro something or other for video.
GPS: https://www.dualgpssolutions.com/exp...roduct/xgps160 Stitch it all together with Dashware. http://www.dashware.net/ Probably not the easiest way to do it, but works fine for me. Output looks like this, although the gauges etc are all customisable: If I could be bothered plugging in an ODB2 reader, I'd be able to get throttle, etc etc, but that all seems too much effort <edit> I should note... The 10hz GPS was important to get better quality telemetry. Iphone GPS just doesn't update quickly enough to give good track data. Last edited by bloke79; 01-06-2022 at 04:58 PM.. Reason: additional info. |
01-06-2022, 06:12 PM | #3 |
1107
Rep 1,301
If you just want the basics, I think the following setup (what I use) strikes the best balance between ease of use and what you get:
RaceChrono + external GPS + wireless OBD2 + GoPro Optional: Add a cheap wired lavalier mic to the GoPro, run it through your trunk, and tape it to your license plate for better engine sound. Everything talks to your phone/RaceChrono pretty seamlessly. I use the SkyPro XGPS160 With this setup, you do need to import the corresponding GoPro vids into your phone (using a portable card reader), then you ID those vid files within RaceChrono to synchronize with the data. It's auto-sync feature works quite well, click one button and done. Then, also within RaceChrono you export the sync'd vid with whatever overlay you want to an mp4. You then can send that file wherever. Here's one of my vids with this setup |
01-07-2022, 06:58 AM | #4 |
1094
Rep 920
Lots of people like the garmin catalyst - $1000.
@Jfritz27 where/how is your gopro mounted in that vid? Seat back suction cup with extension arm? by the way, Senna was also a head tilter. |
01-07-2022, 07:46 AM | #5 |
1020
Rep 910
[QUOTE=jfritz27;28437033]If you just want the basics, I think the following setup (what I use) strikes the best balance between ease of use and what you get:
RaceChrono + external GPS + wireless OBD2 + GoPro Optional: Add a cheap wired lavalier mic to the GoPro, run it through your trunk, and tape it to your license plate for better engine sound. Everything talks to your phone/RaceChrono pretty seamlessly. I use the SkyPro XGPS160 With this setup, you do need to import the corresponding GoPro vids into your phone (using a portable card reader), then you ID those vid files within RaceChrono to synchronize with the data. It's auto-sync feature works quite well, click one button and done. Then, also within RaceChrono you export the sync'd vid with whatever overlay you want to an mp4. You then can send that file wherever. Here's one of my vids with this setup Nice! I have a wireless dongle, I'll see if it works. I have an iphone and can't use a card reader??? Doesn't GoPro synch to your phone already? |
01-07-2022, 08:39 AM | #6 | |
1107
Rep 1,301
Yes, gopro mounted to suction mount on rear passenger seat with extension bar. When on track I have it tethered with paracord. EDIT: And in GoPro I'm using the shake reduction on the most mild setting. You definitely need some, it's amazing what even the mild setting does. Last edited by jfritz27; 01-07-2022 at 08:45 AM.. |
D_SheerDrivingPleasure1094.00 |
01-07-2022, 08:44 AM | #7 | |
1107
Rep 1,301
[QUOTE=FrankMstein;28438501]
This is the reader I use, works fine: https://www.amazon.com/Reader-Adapte...83&sr=8-8&th=1 |
FrankMstein1019.50 |
01-20-2022, 10:18 AM | #8 |
10744
Rep 3,690
RaceChrono Pro has always been my favorite. User friendly, great interface.
I loved my Garmin Catalyst and now you can pull video with telemetry data which makes it even better. That was one of the earlier complaints. It does come with a high entry fee but you take care of GPS/Camera/App with one unit which makes it easy to take on the go. I can't tell you how many times I've forgotten my XGPS, a battery for my GoPro or a memory card. I sold my Catalyst after my crash at WGI because I wanted to give it a little bit of time to regain confidence in my new car before I start pushing corner speeds and overall lap times. (It survived an almost 100 mph crash) Highly recommended otherwise. |
FrankMstein1019.50 jmg18708.00 |
02-18-2022, 07:57 AM | #9 |
64
Rep 52
There is another option for those who want to spare some bucks (my case). Recently, I've put together some code to use a GoPro as video and GPS along with the MLaptimer app. It is very straight forward to use, no need for wiring into any ECU neither pairing different devices via bluetooth. All you need is to go out on the track while recording with the GoPro and with the MLaptimer app. By the way, the MLaptimer for iPhone is a really cool app, specially if you consider that the car sensors (but the GPS) are very accurate.
The code I've put together will parse the MLaptimer low res GPS track with the high res GPS track from the camera, sync everything together, and output a csv file for rendering videos with Dashware or RaceRender. Even better, it also outputs a .vbo file, which can be used in CT to analyze the driving, with very good quality (of course, quality depends on how good you set up the GoPro). Check the results below and access www.easy-telemetry.com to know more. Note: processing the app files is free, but there is a little fee for processing GoPro files. |
FrankMstein1019.50 jfritz271107.00 |
02-18-2022, 09:47 AM | #10 |
30
Rep 39
I still go super basic and just use Harry's Lap Timer using my phone camera and a basic short armed Ram mount to the windshield. If you're only looking for lap times/video/basic data logging and don't have a GoPro, then this is probably one of the least expensive ways to start. Can easily build up from there with other additions (external GPS, GoPro, etc.), but Harry's has been solid for our group.
02-18-2022, 12:08 PM | #11 | |
64
Rep 52
02-18-2022, 01:40 PM | #12 | ||
30
Rep 39
02-19-2022, 11:46 PM | #13 | |
18708
Rep 14,115
Drives: G82 M4C X-Drive
Echoing what has been said, get an external faster GPS device instead of using the phone's GPS.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
TrackEnthusiast63.50 FrankMstein1019.50 |
03-16-2022, 03:33 PM | #16 | |
64
Rep 52
About the GoPro GPS quality, it really looks like it is no good, but maybe it could be the processing or the rendering of the track pic that is the problem. If you process the data in my website then I can take a look at it and see if the problem is the data or the processing. Just go to https://easy-telemetry.herokuapp.com/ , subscribe and then you can process your videos for free. Another thing that could have happend with your GPS data, is that in Road Atlanta the sky was really clear and in Charlotte the day was cloudy, but usually that doesn't give that much difference. Another important thing to nottice is if you gave the cameras GPS enough time to get a GPS lock before start recording. Check out the video below about how to get good GPS signal with GoPro: PS: Why dont you use the BMW MLaptimer app to get the cars data? The datas on your videos doesn't look as accurate as you would get with the app. Check the video below for comparison: |
03-16-2022, 03:43 PM | #17 |
1020
Rep 910
Thanks! Those videos and not going to be public for insurance or warranty reasons. Probably doesn't matter anyway. It was cloudy that day on and off. I will try and see of I can upload. Technology these days is not agreeing with me but I'll try. Look at those G forces at the bottom end of RA, 5G, LOL, as if!
RA was 18 deg and ended up 48! CMS was 69 and ended up 60. My CCB's are probably fried. I would do Carolina Motorsports Park next weekend if it weren't for that. I have a friend that is an expert at carbon ceramics to look at them after I weigh them. |
03-16-2022, 04:42 PM | #18 | |
18708
Rep 14,115
EDIT: nevermind, I just saw you earlier post. So you just dump the GoPro video and data from the app into Dashware or RaceRender?
03-16-2022, 05:02 PM | #19 |
18708
Rep 14,115
Another option, if you want instant feedback and some AI "coaching" is the Garmin Catalyst. The Catalyst does not get data through the OBDII, but though GPS and the camera to analyze your position on the track. It gives coaching cues through each section based on your fastest time through the section for the day. It also gives you feed back and 3 “opportunities” to reduce your lap time, also based on your other laps including brake zones, apex placement, and speed. You can do this right on the device immediately after each session. You can watch your video right on the device.
I use both RaceChrono and the Garmin Catalyst. The Garmin's video is not as good as the 4K Gopro, obviously, but it's much easier to put it together, you just export it right from the device onto a card. With RaceChrono I have to import the GoPro then line up the video, choose my layouts and export... it's a few more steps you can't do at the track unless you bring a laptop or transfer the 4k footage from the GoPro to your phone, which takes a LONG time. Anyway, here is the same lap recorded by two devices, you can see how each is different. Notice the Garmin coaching me through the course: My current setup with RaceChrono and the Garmin Catalyst:
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 Last edited by jmg; 03-16-2022 at 05:08 PM.. |
TrackEnthusiast63.50 |
03-16-2022, 05:03 PM | #20 | |
64
Rep 52
However, if you film your session with a GoPro with GPS enabled AND record with the MLaptimer app, then you'll have 2 sets of data with 2 GPS tracks. Then, if you process the video and the MLaptimer fille in the website, the code in the server will integrate the 2 data sets into 1 with 20 pts/sec for all the data (position and car signals). With this data set you can render videos without the need to manually synch and even better, use circuit tools to analyze your driving. Last edited by TrackEnthusiast; 03-17-2022 at 07:05 AM.. |
jmg18708.00 |
03-16-2022, 08:17 PM | #21 | |
1020
Rep 910
03-16-2022, 10:00 PM | #22 | |
18708
Rep 14,115
Importing: My advice is to not import the whole video, it takes too long. Unless you want to compare other laps, just import the fastest lap. Syncing: I use a OBDII adapter to capture speed and RPM, and I find that syncing to RPM is the easiest since I can hear it in the video and see the RPM graph. Super fast. I can usually do it in under a minute. Here is my step-by-step: Import GoPro footage into my desktop. Find the fastest lap (I usually have the Catalyst or RaceChrono in view of my helmet cam so I just compare lap times) Use Quicktime to trim the very large 4K GoPro footage down to that one lap Import that .mov file into my iPhone Move that video into RaceChrono album Open RaceChrono and then open your session. Click the "Video" button Import the video Use the RPM method I described above to sync Click "Export" in the menu Under "Scope" select "Laps" Select the fastest track as the "Start Lap" Select the next lap as the "End Lap" Select my Video Overlay Setting Select "Very High Quality" especially if you are recording in 4k Add to queue Start When it's done you still have to copy the video to your photo album
