12-31-2021, 05:21 PM | #1 |
139
Rep 271
Main Battery positive terminal
Anyone know what the two red wires are for ? They are connected to main battery positive terminal. Looks like all F85 F86 does not have them. My car is 2016 F86 X6M
12-31-2021, 05:49 PM | #2 |
4503
Rep 7,545
The battery safety switch is attached to the positive battery cable (#2 in the diagram below)…as well as the underfloor positive battery cable (#3 in diagram below) that attaches to the alternator, starter, and positive jump terminals in the engine bay.
For more info about the battery safety terminal and its function (how a pyrotechnal charge separates the battery from the engine bay in an accident…yet the battery still supplies power for emergency functions like interior lights and unlocking the vehicle…read info below:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-31-2021 at 05:58 PM.. |
ajob463.50 |
12-31-2021, 07:47 PM | #3 | |
631
Rep 1,233
Separate question
12-31-2021, 08:02 PM | #4 | |
4503
Rep 7,545
Also, using the engine bay terminals…if charging the battery…it runs it through the IBS (intelligent battery sensor). If you connect directly to the battery, the IBS is left out of the equation and when the vehicle is powered back up…the IBS can misinterpret the change in the battery and cause check control warnings.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-31-2021 at 08:10 PM.. |
1004ron26.50 |
12-31-2021, 08:47 PM | #5 | |
631
Rep 1,233
Okay
01-01-2022, 05:25 PM | #6 |
4503
Rep 7,545
Since the reason for using a power supply is to prevent the battery from discharging while coding…I personally prefer a battery tender/maintainer that plugs into a wall outlet. I don’t trust jumper battery packs.
I use a BMW branded battery charger/maintainer. You can find them all over the internet…as well as the oem equivalent brands which make the BMW branded charger/maintainers.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
01-01-2022, 05:38 PM | #7 | |
631
Rep 1,233
01-04-2022, 08:47 PM | #9 |
139
Rep 271
After research realized these two red wires are from aftermarket amplifier previous owner installed. I unplugged them, taped it off and stuck them under the bumper.
