10-20-2021, 01:58 PM | #1 |
36
Rep 426
Drives: 2004 BMW M3
2020 BMW X3M COMP
UPDATE: Water Pump
I am looking for a little bit of help in diagnosing this noise. When the A/C or heater is blowing, there is a loud buzzing noise coming from under the hood. It seems to be almost dead center on the front of the motor, right behind the radiator. It only makes the noise with air blowing. It goes away when you turn the air off. I did notice that if the heat or air is blowing and you shut the car off, the noise lasts about 5 more seconds. I did take a video and will try to upload it for reference. Thanks for any advice or insight before I end up paying the dealer to diagnose it.
2004 BMW M3
2013 BMW X5 35i 2008 BMW 335xi http://koloa.com/?afmc=8t |
10-20-2021, 02:12 PM | #2 | |
36
Rep 426
Drives: 2004 BMW M3
2020 BMW X3M COMP
2004 BMW M3
10-20-2021, 03:14 PM | #3 |
538
Rep 872
Maybe something caught in the cooling fan and the blades hitting the object? I caught a license plate once in my E36M3...now that was loud.
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 |
10-20-2021, 05:42 PM | #4 |
36
Rep 426
Drives: 2004 BMW M3
2020 BMW X3M COMP
I will check that out. Last week it seemed like it only made that noise when it was blowing full blast. Now it doesn't matter what setting it is on.
2004 BMW M3
10-21-2021, 12:50 PM | #5 | |
2022 M4 Comp Xdrive
1019
Rep 1,538
• There's an aux pump for the turbos. • One for the intercoolers • And a third for the main system/and heater core. Yours sounds like it's the auxiliary pump for the main system (not the belt driven one on the block). That one is in the driver side front bumper area. |
10-22-2021, 04:07 PM | #6 |
36
Rep 426
Drives: 2004 BMW M3
2020 BMW X3M COMP
After a little more troubleshooting, I tried running the A/C and the heat and the noise happens in both settings. I noticed that if I start with the temperature at 60 degrees the noise is not present. But as I raise the temperature, a degree at a time, the noise starts and gets louder the higher the temperature.
2004 BMW M3
10-22-2021, 04:59 PM | #7 |
36
Rep 426
Drives: 2004 BMW M3
2020 BMW X3M COMP
Another Video. After I let the noise run for probably 5 minutes while waiting for radiator fan to kick on, I noticed the noise and the air would start to get loud and then quiet. I also noticed that no air was actually blowing out of the vents except for the rear seats and the windshield defrosting vents.
2004 BMW M3
11-11-2021, 03:59 PM | #8 |
36
Rep 426
Drives: 2004 BMW M3
2020 BMW X3M COMP
Just an update… ended being the water pump. I dropped it off at the dealer and he called saying it was the water pump and that it was covered under warranty. I guess in relation to the class action settlement. Luckily saved a nice chunk of change. Thanks for all of the input.
2004 BMW M3
