10-01-2021, 06:13 PM | #1 |
293
Rep 624
$5000 to blow
I recently discovered I love track days and want to put a little money into my car. Currently stock everything except SRF fluid and ferodo ds1:11 pads. What would you spend the $5000 on and why? Thanks
10-01-2021, 06:58 PM | #2 |
/M Enthusiast
1599
Rep 1,619
Ok, I will play.
Generally first mods to track a F8x are camber plates, more negative camber to the front and rear of the car, some track tires, maybe wheels. This will get you really far.
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
phefner369.00 |
10-01-2021, 08:25 PM | #3 |
drunk poster
6613
Rep 3,649
Answer is in the title, $5000 to blow
J/k, track tires is my reco. Once you wear out $5000 of tires, you'll know what exactly to spend the next $5000 on, and so it goes… |
fiveohwblow3633.00 irunalot1518.00 |
10-01-2021, 10:09 PM | #4 | |
1502
Rep 1,485
However, IMO changing more often fluid allows you to use fluid with higher boiling point. SRF is excellent race fluid but for track days IMO fluid like Motul RBF660 etc. is better choice. |
whitstap79.50 |
10-02-2021, 12:25 AM | #6 |
1930
Rep 869
Best place to spend money in the beginning is on driving instruction. Take something like a three day Barber course, and then get a good amount of track time under your belt.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
10-02-2021, 03:59 PM | #7 | |
18708
Rep 14,115
Drives: G82 M4C X-Drive
$1-2k - Instruction first if you are new to the sport. $600 - Camber Plates to save your... $1.6k - Tires $2-3k - Suspension That's right around your $5k budget right there, and money well spent. After that look into track wheels if you find yourself going once a month or more. If not, save your money for track days, tires and insurance, because it adds up!
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
TractionControlDelete4593.00 tyler19520.00 |
10-02-2021, 08:34 PM | #9 |
519
Rep 1,730
Camber plates
Tires Track days The car is already super capable.
2018 Grigio Telesto F80 M3 DCT | :: Bone Stock :: 2004 Titanium Silver E46 M3 6 Speed | :: Track Car :: |
10-03-2021, 12:51 AM | #10 | |
707
Rep 886
Track-able tires, 200tw $1500 Camber plates $450 GTS Diff/steering coding $50 GTS or XP-H DCT tune if dct $50? BM3 & f80paul track tune $1000 F Girodisc rotors $1300 R Race Toe Links w/ eccentric lockout, SPL $350 F Monoballs, sealed, Bimmerworld $350 Alignment $300 $5300 approx. This gives u all around upgrades. Better tires and neg camber, software, more power w/ linear track tune, brake cooling, alignment & feel Then save for MCS 1-way dampers ($4k), crank hub ($3k), fresh tires/pads/fluids ($2.3k)
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
10-03-2021, 08:23 PM | #12 | |
432
Rep 938
i just installed SPL rear toe links this weekend, i didn't know they would really make a difference, but my shop said the eccentric was worn out at the last alignment.
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
10-04-2021, 08:53 AM | #14 |
1094
Rep 920
$5000 to blow
Or you could purchase 200 raffle tickets and hope you win the M2C dream car...
https://www.bmwcca.org/raffle |
10-04-2021, 05:02 PM | #15 |
412
Rep 737
I mis-read... thought it said $5000 on BLOW. I would've brought the hookers???
D_SheerDrivingPleasure1094.00 |
10-04-2021, 05:05 PM | #16 |
1094
Rep 920
bimmerboyE92412.00 |
02-24-2022, 09:44 AM | #17 |
293
Rep 624
Just an update. This is how I’m spending $5000 in Canadian and include shipping and related charges.
Giro disc front discs $1900 Turner front monoball sealed $380 (got a deal) Rogue engineering trans mounts $130 Vorshlag camber plates $950 Replace worn front tires $1000 $4630 spent, the rest should hopefully cover a good alignment. I still wanted to add a couple more things like rear toe links with eccentric lockout, and rear Girodiscs, but it will have to wait a bit. Thanks again for all the advice. My next question is how would you guys spend the next $5000? Hookers and blow right? |
02-24-2022, 10:03 AM | #18 |
10744
Rep 3,690
If I had to do it all over again - I would invest in a 2-way adjustable coil over suspension before spending money on stickier tires etc... Don't buy the M Performance or KW HAS. They're just lowering springs which help center of gravity but are still too soft.
You're not going to maximize grip until you've got the right dampers, springs and camber. I'm a member of the F8x needs a BBK in the front club but even then without the right suspension, the balance of the car will be all over the place under threshold braking. |
02-25-2022, 12:24 PM | #19 |
2182
Rep 1,665
With what you have so far I'd do a street able bucket seat and spend the rest on some good coil overs. Seats/harnesses are the most impactful things for any track car IMO, being strapped in properly makes a huge difference especially under heavy braking.
phefner369.00 |
02-25-2022, 05:10 PM | #20 |
293
Rep 624
I was having trouble staying in my seat on my last track day. I’ve heard good things about the cobra Nogaro seat. Not sure if it would be an improvement over the factory seat or not. Also not sure how I would deal with the airbag warning light. If the car would still drive normally or if I would need to get it coded out.
02-25-2022, 08:20 PM | #21 |
/M Enthusiast
1599
Rep 1,619
Cobra Nogaro in my M2c, a great seat for the price.
Airbags are coded out, also no heated front seats.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune Last edited by Suds; 02-25-2022 at 09:34 PM.. |
