BMW M3 Forum (E90 E92)
      11-15-2008, 12:13 PM   #1
frankzlin79
frankzlin79's Avatar
Drives: 2018 M3
DIY: H8 and H3 Installation (GP Thunder 7500K)
Here are GP Thunder H3 and H8 7500K bulbs.
I will begin by installing the H3 corner light bulb first.
Passenger Side: Cover
Passenger Side: Get two flat screwdrivers (skinny tips) and pry off the plastic with some force simultaneously. You will end up bending part of the plastic on the frame of the car...it will inevitably happen but it's no big deal.
Passenger Side: Here you can see the stock wiring. Although you can barely see the spring clip (bottom of picture), to unhook the clip, assuming you are standing in front of the car, move the clip to the right and it will spring upwards to release the stock H3.
Passenger Side: Here is the wiring harness. I have already disconnected the stock H3 simply by sliding it off from the wiring harness.
Passenger Side: Here is the GP Thunder H3 bulb. (Note, that is NOT my finger, but my girlfriend's, who served as the photographer for this DIY.)
Passenger Side: Connect the GP Thunder H3 bulb to the stock harness by sliding it on.
Passenger Side: Here is the GP Thunder H3 bulb installed and locked in place. This picture was taken standing from the side of the car. You will have to use the spring clip (right side of picture) to press down, then to the left to lock in the GP Thunder H3. Done!
Driver Side: Now, I will install the H8 angel eye bulb on the Driver Side, because it is a whole lot easier compared to the passenger side. Note the angle of the stock location. To release the H8, assuming you are standing in front of the car, rotate the H8 to the right (clockwise) about 90 degrees and the bulb will suddenly loosen. You MUST pay attention to when the bulb loosens out and is free, because to install the new H8, you'll have to begin screwing in at this point.
Driver Side: Very carefully, pull out the H8. You'll need to maneuver through the wires in this confined space. Here is the stock H8 bulb, still connected to the stock harness.
Driver Side: Disconnect the H8 bulb by releasing two clips on the side of the harness. Insert the GP Thunder H8 bulb into the harness. Assuming you are standing in front of the bumper, maneuver and rotate to the left (counterclockwise) the bulb back in place.
Driver Side: Done! This picture was taken at 11:30 am. Although this picture looks like still stock, it is really white.
Driver Side: This is the cornering light. Apparently, the corning lights only turn on when your headlamp switch is in "Auto" (i.e. A) mode.
To install the passenger side, the steps are the same. However, the passenger side is much tougher to install due to the default location of the locked position.
Passenger Side: Default Locked Position
Again, assuming you are standing in front of the car, rotate the bulb to the right (clockwise). The mistake I made was that I was turning the bulb to the left (counterclowise)..stupid me. However, by turning to the right, you'll find that this is very difficult due to the confined space. And what's even tougher is doing this step in reverse to lock the bulb back to the default position, because you must guess where to begin the rotation process.
Passenger and Driver Side H3 and H8 Installed:
This is just the daytime running lights on:
This is the daytime running lights dimmed, because the headlights are on. Unfortunately, the angel eyes dim to a yellowish color, that looks like stock.
This is with the headlights off, and the cornering light on:
Some have experienced the need to substitute the stock orange rubber grommets for the ones that came with the GP Thunder. However, I found no need to do this. I found that both passenger side and driver side bulbs locked into place very tightly.
Note: I also got my clear bra installed yesterday, but you cannot see it in this picture (that's the way a clear bra should be). I'll be posting up pictures of the lines of the clear bra in the photos section later.
      11-15-2008, 02:29 PM   #2
kmarei
kmarei's Avatar
Egypt
686
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
i did the same thing
and while the H8 bulbs looks great with the main lights off
as soon as you turn on the main lights (HID) they dim and become more yellow
and the H3 lights seem to be a lot dimmer than the sock bulbs
i am thinking of getting the 100watt version not 55w like stock
      11-15-2008, 04:48 PM   #3
frankzlin79
Drives: 2018 M3
I would only use stock wattage for after-market bulbs. The wiring harness is designed only to use the stock wattage. You could fry your electrical system if you put a higher wattage bulb.
I'll have to take another picture later tonight and see how bright they are. If I don't like them, then when the 7500K bulbs burn out, I'll get the 8500K bulbs.
      11-15-2008, 11:57 PM   #4
Rick
Stackin' Chips
Rick's Avatar
171
Drives: 2008 AW M3 Coupe
Nice DIY
      11-16-2008, 02:15 PM   #5
frankzlin79
Drives: 2018 M3
Thank you, thank you.
      12-14-2008, 03:56 PM   #6
M3Cat
10
Drives: 2024 M2
Thanks for the great DIY. It was easy - even for us girls.
Current: 2019 M2 Comp, 2015 Cayman GTS, and 2020 BMW X3M
Past: 991.1 911, F82 M4, W205 C63S, B8 RS5, F13 650, E90 M3, E92 335is, E46 M3, E70 X5
      12-15-2008, 04:52 PM   #7
danny929
27
Drives: Interlagos Blue M3 COUPE
sorry for the newbie question but what purpose does which bulb serve (h8 both halos?)
(h3 cornering lights)
      12-22-2008, 06:53 PM   #8
frankzlin79
Drives: 2018 M3
H8 - both halos
H3 - cornering light
I thought it was pretty clear of that in my DIY. *shrug*
      12-25-2008, 11:24 AM   #9
E92-Lighting
E92-Lighting's Avatar
Drives: Next Generation LED Lighting
great DIY guide
      07-07-2009, 12:31 PM   #10
gemini330zhp
gemini330zhp's Avatar
Philippines
34
Drives: 2008 M3 E90
Thanks for posting this DIY I though you had to go into the fender in front of the wheel.
2008 Jet Black E90 M3 6SPD no sunroof and 18s to my specs
      01-25-2011, 06:56 PM   #11
tripm3
Drives: 2009 BMW M3
Great DIY guide, thanks.
      02-17-2011, 08:57 PM   #12
TRY...M3
TRY...M3's Avatar
Drives: Depends on the day
how would it look with just the H8s??
      02-18-2011, 01:48 AM   #13
JCtx
258
Drives: No BMW yet
The same... unless your cornering lamps are activated (at night, and with the light switch to the left in 'auto'). I didn't replace them either since I seldom drive at night, but will next time I order GP Thunders again.
      02-18-2011, 06:42 PM   #14
E92-Lighting
you can also follow Shinchan's Gp Thunder install guide
      02-19-2011, 02:20 AM   #15
orion_squall
Drives: E92
How long did those bulbs last? My collegue complains about burning after market bulbs...I hope those can last long
      02-19-2011, 11:01 AM   #16
geneatals
Ninja
geneatals's Avatar
Drives: 2019 530e
my GP's lasted me about 30 months, DRL's on all the time...
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i
      02-19-2011, 11:38 AM   #17
TRY...M3
TRY...M3's Avatar
I just installed the H8s and it seems like only the inner rings are brighter but where I ordered them from they said that the H8s are for all 4 angel eyes? Help please
e92///M3
TT Lamborghini Gallardo
INSTAGRAM: CHRISTIANPERLES
Lamborghini-Talk.com: Christian.
      02-19-2011, 11:56 AM   #18
geneatals
Ninja
geneatals's Avatar
Drives: 2019 530e
the inner ring light is reflected into the outter ring light, so no matter what the inner ring will always appear to be brighter..even with HID and LED set-ups....
so 2 bulbs for 4 rings.....
      02-19-2011, 12:02 PM   #19
TRY...M3
TRY...M3's Avatar
Okay thank you...so is it worth buying the H3 what exactly will that do for me
e92///M3
      02-19-2011, 12:04 PM   #20
geneatals
Ninja
geneatals's Avatar
Drives: 2019 530e
in your manual: cornering lamp....so like any other bulb swap, it will change the color of the existing bulb....
      02-19-2011, 12:10 PM   #21
JCtx
258
Drives: No BMW yet
Don't hold your breath. I initially put 8,500s, and lasted 5K miles. Now I put 7,500s; we'll see. My guess is whatever coating they put makes them hotter inside, and burn out quicker.
They're designed that way, and I like it. And yes, 1 bulb per side. The GPs are the perfect solution for me, as they're DRLs, not headlights .
      02-19-2011, 03:05 PM   #22
TRY...M3
TRY...M3's Avatar
Maybe it's just me but the outer rings seems a lot more yellowish
e92///M3
m3post
