09-15-2021, 08:33 PM | #1 |
1099
Rep 2,286
Brake or Pedal Fade on Track - stock rotors PFC08 Pads?
I just experienced brake pedal fade on track for first time this weekend in tracking the F80 since 2016 (average 3-4 track events per year since then).
I have the stock rotors and calipers - with PFC08 pads. I do mot have stainless steel brake lines - and I get my brake fluid swapped out once per year with the Super DOT 4 fluid (first track event of the year with this fluid). I'm trying to determine the potential causes of this - fluid is just barely below maximum level - and my lap times were no faster than before and same category of tires (Michelin Cup 2). Maybe just need stainless steel brake lines? Other ideas or suggestions? Thanks in advance, |
09-15-2021, 09:24 PM | #2 |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
I'd guess that your Super DOT 4 fluid is boiling. It doesn't have a very high boiling point (about 100F lower) compared to the typical track fluids (Motul/Castrol).
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
09-15-2021, 09:31 PM | #3 |
92
Rep 299
Sounds like it. Changing out to Motul/Castrol prior to next track event is probably the most cost effective way to see if the issue presents itself again.
09-15-2021, 10:05 PM | #4 |
/M Enthusiast
1599
Rep 1,619
M4, I am using Castrol SRF Dot 4 changed every 12 months, stock brakes and lines with PFC08 brakes, no problems.
I ran SCCA time attack last month with no problems.
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
09-15-2021, 11:07 PM | #5 |
220
Rep 248
As others said. Once you get some nice fluid in, you will be golden. Stock setup with pfc and nice fluids can easily last a long 45 minute session and not break a sweat.
Stainless is more of a luxury than any true gain, I was a little let down when i got them. I would say it negligible.
'16 F80 M3 DCT
TC Kline coilovers and camber plates, Apex 18" EC-7, Conti ECF 295r/275f, monoball thrustarms, SPL toe arms, Powerflex diff bushings/bracket, AP Racing 9660, Project Mu H21, Spiegler brake lines, AA midpipe, VTT crankhub, VRSF charge/j pipe, Turner tray, BM3 CS Youtube: Driver407 |
chrisjguzman95.50 |
09-16-2021, 09:53 PM | #6 |
21117
Rep 20,741
Drives: 2021 911 turbo
What do you mean by "brake pedal fade" ?
Is it that your pedal gets long but you still have braking power? Or is it that you don't seem to get enough braking power despite pressing hard on the pedal?
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
09-17-2021, 01:23 PM | #7 | |
18710
Rep 14,115
Drives: G82 M4C X-Drive
Brake fluid and pads have a temperature in which performance will start to fall off steeply. When brake fluid goes above boiling temps, you will feel sponginess. When brake pads get too hot, you will get glazing and/or that deep sinking feeling in your gut of the car not stopping like you want it to. Glazing will lead to deposits which lead to vibrations during braking along with increase in braking distance.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 Last edited by jmg; 09-17-2021 at 05:07 PM.. |
09-17-2021, 02:34 PM | #8 |
10744
Rep 3,690
It's all going to lead up to you getting a BBK. Skip all the in-between, trust me.
Intensemojo87.50 |
09-17-2021, 04:39 PM | #9 |
1099
Rep 2,286
It would be longer pedal travel - any insights you could provide would be great!
09-17-2021, 05:07 PM | #10 |
18710
Rep 14,115
That's air in the system as a result of boiling your fluid. Definitely switch to Castro SRF or Motul 660.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
09-17-2021, 05:44 PM | #11 |
21117
Rep 20,741
Have you considered it could be caused by pad knock back?
09-17-2021, 08:48 PM | #12 |
1099
Rep 2,286
I have not considered that - but either way I think I need to upgrade to Castrol SRF or the Motul (not sure about pros/cons of each - but they both seem to be great options compared to what I'm using right now)!
09-18-2021, 07:41 PM | #13 |
519
Rep 1,730
FCP stocks motul so grab 2 bottles there and fluid flushed will be free w warranty!
2018 Grigio Telesto F80 M3 DCT | :: Bone Stock :: 2004 Titanium Silver E46 M3 6 Speed | :: Track Car :: |
