09-13-2021, 01:48 PM | #1 |
Rep 37
Suggestions for E60 M5 wheels (or similar) settings
Hi folks,
I'm always fascinated by the E60 M5 stock wheels since when I was still a kid. After some googling, I found out that it's a Style 166 with 8.5x19 ET12 and 9.5x19 ET28, which seems to be a stretch for the 135i. http://www.bmwstylewheels.com/bmw/166 I planned to put PS4S or something similar on it, and google said that the 1M had 245/35 and 265/35 settings. What do I need to do with this setting? And if this 19in is too much for the car, is there any similarly styled wheel available in 18in? Finally, just a stupid question, are these M OEM wheels any good performance-wise? It is said that the M5 wheels are made by BBS. Thanks! |
09-14-2021, 08:33 AM | #2 |
1Addict
3233
Rep 7,894
Won't fit the narrow body 1er. Not even close. You'll be around 30mm too much poke on the rear alone and fitting a 19x9.5 is tough with proper tire sizes even with appropriate offsets.
You can probably find reps that will, or aftermarket wheels which look similar. Lots of good stuff available.
09-25-2021, 10:56 AM | #3 |
105
Rep 133
Style 135 from the E46 ZHP is somewhat similar, and those fronts will fit our 1-series. I love these style 135 wheels:
http://www.bmwstylewheels.com/bmw/135 |
Tags |
135, 166, 19 inch, e60 m5 |
