09-09-2021, 10:19 PM | #1 |
263
Rep 264
Are these tires SPENT?
Went to Willow Springs a few weeks ago. First track day in 15 years. Was having some problems getting my tires dialed into the right temperature. Started too low. Kept them too low. (started them at 26-28 seems like I should have started at 34...) I knew I beat the hell out of them. I had a lot going on that day and should have been focused on my tires but wasn't.
My question is, do they have anything left on them? The rears are fine. Can I use them for a few more track days? [rears, not pictured, appear to be fine.] |
09-09-2021, 10:32 PM | #2 |
/M Enthusiast
1599
Rep 1,619
I would consider them ok for daily driving, but I wouldn’t take them to the track again.
If you are getting into tracking I would suggest some track wheels with track tires. 666M’s are a heavy rim with limited tire choices. I would go with a 18” or 19” rim, there are a lot more tire choices.
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune Last edited by Suds; 09-09-2021 at 10:38 PM.. |
09-09-2021, 10:38 PM | #3 | |
263
Rep 264
I'm gonna pound the pavement tomorrow and see if I can find some Apex wheels. |
Suds1598.50 |
09-09-2021, 10:42 PM | #4 |
4589
Rep 1,693
Seems like a stretch for another track day. How were the tires responding to your inputs in your last session? What was your best lap time versus a representative lap in your last session?
DSC, you say? Never heard of it
https://youtube.com/@tractioncontroldelete |
09-09-2021, 10:51 PM | #5 |
/M Enthusiast
1599
Rep 1,619
Titan7 does have 18x9.5” x 18x10.5” so you can run a Nitto 275/35/18 front and 305/35/18 rear. It’s a great combination.
I am also running square 275/35/18 on two sets of rims that are 18”x10”wide.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
09-09-2021, 11:03 PM | #6 | |
263
Rep 264
I was mostly trying to get used to having my butt in IRL seat. (I do a lot of sim racing..). My plan is to go square corners so I can find tires and rotate accordingly. I know I might give up some grip but it seems like a smart sacrifice. |
TractionControlDelete4588.50 |
09-10-2021, 12:15 AM | #8 | ||
4589
Rep 1,693
I haven't done sim racing before although it looks really cool… I see these guys on YouTube with $15,000 setups and it's fun to watch. Did you feel like what you've learned in sim racing helped for your first real world track day??
09-10-2021, 12:39 AM | #9 | |
263
Rep 264
The thing is, I've been doing track days since 1999. I just stopped around 2008 because of the recession. Sim racing got me wanting to do track days again. I used to race in the Skip Barber regional series in the RT 2000 open wheel open cockpit formula car. That is what I mostly race on Iracing. Same car. It's 9/10's just like the racing I used to do. If you have any questions, feel free to ask.. I love talking SIM racing. It's freaking awesome. [IMG][/IMG] |
09-10-2021, 12:42 AM | #10 | |
263
Rep 264
What would necessitate camber plates? Is it driving style? If I change my wheels and tires to 18"s and inflate them properly, you still think I will need plates? |
09-10-2021, 02:03 AM | #11 |
263
Rep 264
Okay, just ordered some Apex SM 10. Square corners.
18X10" ET25 APEX SM-10 Think I'm gonna mount them with Falken Azenis RT615 275x35 r18 How's that setup sound for track days and commute to track? |
09-10-2021, 10:42 AM | #12 | |
11
Rep 33
To compensate for this static negative camber is added to the front end. Negative camber is the top of the tire is titled inward compared to the bottom of the tire. From the factory the car has about 1 to 1.5 degrees negative camber with no adjustment. To increase this, you need camber plates and/or longer lower control arms. The camber plates move the top of the strut inward and the longer lower control arms move the bottom of the hub out. My guess is your need 2 to 2.5 degrees negative camber for street tires, which you can get with camber plates. If you go to Hosiers, you might need up to 3.5 degrees negative camber, which may require the lower control arms with the camber plates. |
09-10-2021, 11:00 AM | #13 | |
1093
Rep 920
Personally, I recommend NT01, especially if you aren't daily driving (loud and awful in the rain) They wear like iron. I start at 28-29 cold and get up to 37psi hot. you will also want a track oriented brake pad and some high temp brake fluid. lots of options. camber plates are nice too. that's about all you really need with this platform until you get really fast. enjoy. |
09-10-2021, 11:00 AM | #14 |
11
Rep 33
For street tire pressures on the M4, I start with 32 psi then bleed down to 36 to 38 psi hot. With Hosiers on a Camaro, I start with about 28 psi and bleed down as necessary.
I am not sure what they signs of an under inflated tire is at the track, but my guess is the damage is closer to the center of the tires. Plus, if you start too low the bead my pull off and deflate the tires (been there). |
09-10-2021, 11:14 AM | #15 |
1093
Rep 920
That sim setup is incredible. FWIW, a coworkers cousin is a pro driver (IMSA) who trains with a sim. He says his lap times are within tenths of second of his actual track performance.
This has come a long way since Gran Turismo. |
09-10-2021, 12:33 PM | #16 |
///M Powered for Life
11490
Rep 10,329
I think the tire wear is due to camber, not underinflation. Starting at 27 cold is nothing crazy.
You would have done better getting 10.5 square tires vs the 10. More support for your tires with a relatively heavy car = happiness |
09-10-2021, 04:39 PM | #17 |
263
Rep 264
Would you mind linking me where I can buy these said plates? I have no experience with camber plates at all. Also, I'm going to 18"s for the track. DO you make the same recommendation for a different wheel?
09-10-2021, 05:04 PM | #18 |
1107
Rep 1,301
I suggest going with the Vorshlag camber plates. If you want the easiest on-the-fly adjustability, I think these win over Ground Control (seemingly the most popular option around here). People also seem to like Milway, but Vorshlag more easily available in the US
https://vorshlag-store.com/products/...ilover-perches If you're going for an 18" square setup (not what I have, but am contemplating), agree with going for a 10.5 wheel. You could potentially run a 295/30/18 square setup on that with ~-3 of front negative camber and an appropriate spacer up front |
09-10-2021, 05:26 PM | #19 | ||||
18705
Rep 14,115
Drives: G82 M4C X-Drive
If you absolutely had to, you could flip these tires or rotate left to right and monitor them every session. Quote:
I got Ground Control camber plates based on the popularity here on the boards amongst the F8X crowd and they haven't dissapointed. Quote:
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
09-10-2021, 11:10 PM | #20 | |
11
Rep 33
Here are some good videos on camber plates. https://youtu.be/sAaLvIqSRV4 https://youtu.be/qoOqc5uFmZQ |
09-11-2021, 01:14 PM | #21 |
263
Rep 264
Are camber plates just for the front?
Or do you need two sets? 1xfront? 1xrear? How long do they take to install? Can any garage do it or a speciality shop is necessary? |
09-11-2021, 01:27 PM | #22 | |
18705
Rep 14,115
Install takes an hour or so. If you are getting coil-overs just do it in one shot. Any performance/enthusiast or competent mechanic can install it, but an alignment shop needs to dial it in. Since you are local to me, I'd recommend WEST END ALIGNMENT, who are in the middle of a relocation, or CHEWERKS. I've used both for track setups and they are both great. I've also been to MINI CORSA in North Hollywood, but they actually outsource their alignments to another shop, which I didn't know at the time so I couldn't do a driver loaded corner balance.
