08-23-2021, 06:25 PM | #1 |
6580
Rep 5,304
Solution: Remote Reservoir Hose Protective Sleeve/Routing
I know this is a very specific topic, but I couldn't really find any good info on it. So I thought I'd share with you the cheap/effective solution I found for routing your remote canister hose through a protective sleeve.
When I initially installed my RS Pro 3W, I didn't add any protective sleeve when I routed the hoses up to the engine bay. Like most everyone, I routed through the hole that the brake lines go through. When I finally got around to tackling this job this weekend, I found that the rubberish coating on the steel braided hose was already torn and rubbed off at the location that the hose made contact with the metal. I also found that when I turned the wheel lock to lock, the hose was being tugged through the hole and there was quite a bit of resistance. Whew, I'm glad I didn't wait too long before doing this. The criteria I was looking for: a protective sleeve that is semi hard but a little flexible. It had to be able to protect the reservoir hose, but move freely through the sleeve. The sleeve I found is an EVA plastic air/water hose with threaded reinforcement. It has a slick like texture that kind of acts like a natural lubricant. It's firm enough that it can hold it's shape, but flexible enough to route through the engine bay to the wheel well. Here is a link to the part: https://www.mcmaster.com/5632K36/ The ID is .75 inch and the thickest part of my Quick Disconnect is about .79 inch. But I was able to push it through the EVA hose with a little bit of WD40. Be sure to tape off the tip of the disconnect before doing this. Here's a video of the initial test before I buttoned everything up. Picture of my Quick Disconnect. A couple of additional notes. When I buttoned everything up, I also shaved down the metal bracket for the swaybar endlink as it has some sharp edges. The reservoir hose doesn't make contact with the bracket, but comes pretty close when the wheel is turned lock to lock. So I figured to be safe than sorry. Hope this helps anyone who had questions about this very specific topic. |
08-25-2021, 04:55 AM | #2 |
///M Powered for Life
11490
Rep 10,329
Thank you for posting!
08-25-2021, 02:02 PM | #3 |
707
Rep 886
I wrapped my remote canister pinch points with gorilla tape. It was meant as a temp fix but it works well!
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
08-25-2021, 02:35 PM | #6 |
707
Rep 886
Ahh ok, your lines are routed differently than mine. Under our air boxes you can move the wheel well plastic a bit to snake the line through…I had only 1 pinch point routing that way and the lines remain hidden
08-25-2021, 02:42 PM | #7 | |
6580
Rep 5,304
