07-25-2021, 05:04 PM | #1 |
Combined Applications Group
1059
Rep 680
Michelin Cup 2 - Delamination
Track car issues Front tires on my M4, 285/30/19 Cup2 ZP 94Y delaminating after 42 laps. Great wear assides from the delaminating. Rear 305/30/19 98Y wearing beautifuly 0 issues. I read about this being a common issue with CUP2s on track. I ran them 32psi max hot f&r, outside temperature ~26celsius. Car settings: Front -4.1 Camber 0.02 degrees toe in per side 550 lbs springs 1" suspension travel before bumpstops Whiteline sway bar full soft setting Apex SM10 19x10 + 25 15mm spacer Rear -1.9 Camber 0.10 degrees toe In per side 750 lbs springs 1" travel before bumpstops. Oem sway bar Apex SM10 19x11 + 44 10mm spacer Big Front splitter plus rear wing. PowerStop track day pads F&R (excellent excellent pads,0 fade, great feel) Car is not under steering nor over steering it's planted. Quick idea of the setup in the car pix. Voltex wing and home made splitter and sides Started 28psi cold F&R I do 2 warmup laps 70-80% pace before going hard on them for the rest of the session. Any ideas? Or are these not suitable for sustained track race pace 20min sessions. Thx in advance
07-25-2021, 11:27 PM | #2 | |
528
Rep 855
There are better choices out there: RT660, A052, AR1, CR1, RS4. |
David0ff1059.00 |
07-26-2021, 07:15 AM | #4 | |
1059
Rep 680
It's slightly bumpy on a few spots and I don't bottom out anywhere.
07-26-2021, 08:05 AM | #5 |
518
Rep 582
That's not delamination, that's tearing, in my view. Delamination would happen at the bead. Tearing is due to working the tires past the temperature they can handle. That's why SC2s are not great tires for HPDE format with 20 minute sessions.
2017 BMW M2 5Spd, 2007 VW Touareg, 2023 Yamaha MT09 SP
https://www.instagram.com/dvas99/ https://www.youtube.com/channel/UC2j..._as=subscriber |
David0ff1059.00 SYT_Shadow11490.00 |
07-26-2021, 08:25 AM | #6 | |
1059
Rep 680
I have a video which shows it better than the pix but can't attach here. This is a pic of both tires from the video showing the depth of the area. So really I just have to reduce my intensity? 2-3 max laps 1-2 cool down, repeat?
07-26-2021, 09:39 AM | #7 |
1107
Rep 1,301
You alluded to some tire temps -- if using a true pyrometer, do you have readings from inside, middle, outside? Would agree your pressures don't seem excessive, though...
07-26-2021, 09:41 AM | #8 |
1059
Rep 680
Unfortunately, Saturday, my friend who has a pyro poke thing was not there so I have no readings of tire temp
07-30-2021, 09:00 AM | #9 |
3663
Rep 3,422
Or just bounce from the Cups. Any reason why you're committed to them vs more durable alternatives?
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
07-31-2021, 06:49 AM | #10 | |
1059
Rep 680
Yesterday another track, rear 305 delaminated before noon, same way the fronts did last weekend. Good thing I had my last 2 spare with me.
07-31-2021, 07:11 AM | #11 | |
3663
Rep 3,422
What spec cups are these? Age? Think only specs that might hold up to hard running with our car's weight/power would be the 5-6/32" options like ZP Corvette or Ford. But too many good alternatives out there to try to make any Cups work for dedicated track purposes imo. N spec Cups are plenty durable (tread) but heat cycle out after day 2. They're all a compromise. Too bad because when fresh they're an incredible tire, just give out too soon in one way or another.
07-31-2021, 07:26 AM | #12 | ||
1059
Rep 680
My 4 x 305/30/19 were the Mustang 350R ones My 4 x 285/30/19 were the vette ZP version All ~1000kms street before track All tires were 2019/20 construction
08-01-2021, 01:26 PM | #13 |
Grid.Life
325
Rep 383
Kind of looks like the hot pressure is still getting too high with the blistering always appearing in the middle section of the tire. I start my car out at 25psi cold and have been getting incredible wear lately with this set of RE71R.
Like others have said there are much better alternatives that are also more cost effective, look into the Goodyear Supercar 3 for a good balance of life/grip or Supercar 3R if you want more grip. |
David0ff1059.00 |
08-01-2021, 02:28 PM | #14 | |
1059
Rep 680
