07-08-2021, 06:37 AM | #1 |
Rep 19
Front suspension knock
Experiencing front suspension knock on rebound when fully extended. Mostly noticeable when going slow over speed humps or bumps on the road. The F85 has 46k klm's, I've brought it up with the bmw service tech with them failing to concur.
I find the knock is much less when using sport or sport + I'm planning to replace the OEM front struts or for a bit more expense go for KW. Has anyone else experienced this? It's kind killing my enjoyment of the car |
07-08-2021, 09:06 AM | #2 |
266
Rep 271
I've noticed this too and was thinking of replacing the swaybar links first:
https://www.fcpeuro.com/products/bmw...er-37116771929 $50 for the pair vs about the same for one from BMW. |
07-08-2021, 09:18 AM | #3 |
193
Rep 592
Drives: 2018 X5M , 14%E2%80%99640i ver
These do NOT show as correct for X5///M
07-08-2021, 10:08 AM | #4 |
266
Rep 271
I looked up 37116859653 and FCP Euro came back with the kit "37116771929" Under OE numbers, it shows:
37116859653, 37116857627, 37116771929 37116859654, 37116857628, 37116771930 I was also surprised to see that swaybar links were side dependent. |
07-11-2021, 07:47 AM | #5 |
247
Rep 643
I think it's fairly common, I have the same issue over speed bumps. Annoying, but I don't drive over speed bumps all day.
Not sure if the KW equipped community deals with the same clunking…
2017 X5M, Donnington Grey, Aragon Brown
Eisenmann Pro, Dinan Intake, BM3 Stage 1, XHP Stage 3 21" Vossen VFS-1 on Michelin PSS |
