05-31-2021, 04:32 PM | #1 |
220
Rep 248
Power steering overheating
Currently at thunderhill for a track day, in between lunch. At the end of my fourth session i got an error saying “increased force on wheel” drive moderately. The wheel seemed to have lost power steering and got the wheel icon in dash. I browsed a few posts related to this but there wasnt alot of info. I sat out a session and the error has gone away and everything seems fine now. It is 100+ outside and climbing. I was in comfort steering all day. The wheel was hard to turn but after cooling down it is normal now.
Seems the power steering unit overheated? Anything to worry about? Anyone have more info or experience this? Should be fine once it cooled down?
'16 F80 M3 DCT
TC Kline coilovers and camber plates, Apex 18" EC-7, Conti ECF 295r/275f, monoball thrustarms, SPL toe arms, Powerflex diff bushings/bracket, AP Racing 9660, Project Mu H21, Spiegler brake lines, AA midpipe, VTT crankhub, VRSF charge/j pipe, Turner tray, BM3 CS Youtube: Driver407 Last edited by Driver407; 05-31-2021 at 08:35 PM.. |
05-31-2021, 05:21 PM | #2 |
/M Enthusiast
1599
Rep 1,619
OP which steering mode are you using?
Years ago a friend told me that at the M Driving school they were told to not use Sport or Sport+ because of overheating the electric steering on the track. Maybe true don’t know, I always use efficient.
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
05-31-2021, 05:24 PM | #3 |
3633
Rep 1,397
melanthius255.00 |
05-31-2021, 05:26 PM | #4 |
220
Rep 248
Been in comfort all day. I just ran a session and was fine. I cut the session short 5 minutes because we are running east and west back to back with 20min in between. Think the limited cooldown time was getting to it. At 106* degree now. Only have two more sessions.
Suds1598.50 |
06-01-2021, 05:35 AM | #5 |
21117
Rep 20,741
Drives: 2021 911 turbo
This does not make sense. How can putting MORE assist yield to less overheating. Logically, it should be the other way around.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
NYG10744.00 TractionControlDelete4593.00 |
06-01-2021, 05:36 AM | #6 | |
21117
Rep 20,741
06-01-2021, 07:46 AM | #7 |
10744
Rep 3,690
This is a first. I use comfort steering exclusively with a bunch of 100F+ days at NJMP and LRP. Wonder if it has anything to do with the aftermarket midpipe heat? I only say this because my Z06 transmission started running a lot hotter when I switched to titanium (whole transmission is wrapped in the exhaust pipes).
CanAutM321116.50 |
06-01-2021, 11:00 AM | #8 |
220
Rep 248
I didnt have this issue last year in the same heat. The only two factors that changed from my last track day last month are:
1) Track day was both tracks with 10 20min sessions (instead of usual 5) in the day and only 20 minutes cooldown between each. 2) Removed the dust shield and installed ap racing 9660 up front Going to check in with a local shop sometime this week and try to learn more.
'16 F80 M3 DCT
TC Kline coilovers and camber plates, Apex 18" EC-7, Conti ECF 295r/275f, monoball thrustarms, SPL toe arms, Powerflex diff bushings/bracket, AP Racing 9660, Project Mu H21, Spiegler brake lines, AA midpipe, VTT crankhub, VRSF charge/j pipe, Turner tray, BM3 CS Youtube: Driver407 |
06-02-2021, 09:27 AM | #9 | |
318
Rep 280
IG @velof1
Driver407220.00 |
06-03-2021, 04:53 PM | #10 |
220
Rep 248
So i called hmb motorwerks after hearing several people mention them at the track. Talked to the f80 guy and he said there isnt much to be concerned about.
If it overheats, it just fail safes until cooled off and shouldnt degrade or cause an issue if it happen multiple times. He also hasnt really encountered this issue. He said they are starting to see new issues crop up now that more f8x are on the track. He recommended air ducting if it keeps happening. Avoiding back to back sessions on hottest day of the year is probably wise also... I did look back at my footage from last year and i was in sport steering vs comfort this time in the same conditions. So may try going back to sport at my event on the 20th..
'16 F80 M3 DCT
VeloF1318.00 |
06-03-2021, 05:28 PM | #11 |
707
Rep 886
Throwing this out there just in case...
Pop your hood when in the pits, let the heat OUT. If you have a canopy tent thing, drive under that in the pits, get the engine area in the shade.
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
06-03-2021, 05:47 PM | #12 |
220
Rep 248
VeloF1 was parked next to me, along with an m2. They both pop their hoods. I generally don't have a problem. But after this, I did, haa.
Both of us were right on the edge of the canopy/awning at the track so didnt get alot of shade.
'16 F80 M3 DCT
07-20-2021, 07:13 PM | #13 |
Rep 15
sport and sport + put less assist thats why comfort is comfort bc its the most assisted of the 3. sport and sport+ are closer to no-power steering thus less ps intervention.
07-20-2021, 08:50 PM | #14 |
21117
Rep 20,741
We are saying the same thing
08-05-2021, 05:09 AM | #16 |
4593
Rep 1,696
10-27-2021, 02:53 PM | #17 |
220
Rep 248
Earlier this month i had the EPS overheat again at the tail end of my last session.
Some variables i noted: -90 degree day other than the 110 it happen in the past. -I was in sport steering the entire day. -My buddy Velof1 was there and had no issues in his m4. -Last session was open pit and was scheduled for 60min. I got to around 30min when this happen. Other sessions were ~20min -popped my hood for most the downtime (which i generally dont need/do) Im starting to think the front dust shield removal for my AP bbk may be letting a little more thermal heat through the fender liners and aiding to this issue. I have been debating adding some sort of heat insulation to the front fender area around where the EPS unit it. Anyone have any recommendation on what to use for that? I saw one forum post that mentioned removing the liner and disconnecting the eps/ground wire and cleaning it. Have not done this yet. Reconnecting and/or insulation of some sort are the only two things i can think of atm. (Aside from maybe the eps unit needing replacement) As i have noted and seen looking for more info. There are not many cases of this.
'16 F80 M3 DCT
VeloF1318.00 |
10-28-2021, 01:53 PM | #18 | |
10744
Rep 3,690
10-28-2021, 03:29 PM | #19 | |
220
Rep 248
Just trying to hunt down any variables or potential fixes for it. Feel like it is going to be a uphill battle trying to diagnose at a shop being it only happens in extreme track conditions.
'16 F80 M3 DCT
10-28-2021, 04:26 PM | #20 | |
10744
Rep 3,690
10-28-2021, 04:28 PM | #21 |
220
Rep 248
The f8x have EPS electronic power steering .
'16 F80 M3 DCT
TractionControlDelete4593.00 VeloF1318.00 |
10-28-2021, 07:07 PM | #22 |
10744
Rep 3,690
TractionControlDelete4593.00 Driver407220.00 D_SheerDrivingPleasure1094.00 CanAutM321116.50 vrptstyly58.50 |
