05-20-2021, 06:57 PM | #1 |
371
Rep 280
Will they charge for rotors/calipers wear and tear on lease return?
On lease return, I know that the tires should pass minimum tread depth. Besides this, will I get dinged for stress cracks on rotors and badly discolored calipers from tracking? TIA.
[SOLD] 2020 ///M4 CS
05-21-2021, 08:25 AM | #2 |
10743
Rep 3,690
I think it depends on the dealer if they want to break your balls about it.
In reality, the rotors are a consumable item and if you've got stock brakepads on the car when you return it then you shouldn't be responsible for either. You didn't design the car to get no airflow to the front brakes with low temperature paint. Basically, you should be able to fight it easily. |
ABenLauda370.50 |
05-21-2021, 11:08 AM | #3 | |
371
Rep 280
05-22-2021, 07:04 AM | #5 |
134
Rep 257
I have a similar question as OP. What if the car came with carbon brakes and I return it at end of lease with steel brakes? Everything is in great shape, just carbons swapped for steel rotors? My line would be something like "hey I wore out the stock rotors and replaced with equivalent, its fully functional" I would have to try hard to say it with a straight face because my car will only have like 13-14k miles when I turn it in at end of lease haha
05-22-2021, 08:13 AM | #6 | |
371
Rep 280
I recall reading about something similar where someone pulled this kind of shit with a GTS(?). Don't think it was a lease though.
05-22-2021, 04:03 PM | #7 | |
134
Rep 257
Tell you what though. If I do end up not buying this CS and turning it back in, I am definitely taking the lithium battery. Its the exact same dimensions as the battery in my Lotus and I for sure am not turning in a lease with it. |
05-23-2021, 05:04 PM | #8 | |
10743
Rep 3,690
Rotor/Caliper swap is easy af to do yourself on this car - unless you sold the CCB then find a used set or from a salvage. |
05-23-2021, 06:26 PM | #9 | |
134
Rep 257
They are nice and wrapped up from when I took them off at 3500 miles and I can put them on in my garage in half hour (I swapped the iron rotors on in the first place). |
NYG10742.50 |
