05-19-2021, 11:41 AM | #1 |
528
Rep 855
guide pins on stock calipers - keep popping out
Hi Guys,
I'm not sure if anyone has experienced this but it's happened to me 2-3 times. After a track day the guide pins on the stock calipers tend to pop out of their holes (rear is the worst). I guess there's alot of vibration under braking. I'm using DS1.11 pads - these don't have the 'pad stop guides' like the stock pads (not sure I describe that well - but its the metal tabs at the top of the pad that prevent the pad from sliding inwards.) Any suggestions on how to avoid this issue? (better solution). It's very alarming that this can happen. Steve |
05-19-2021, 12:00 PM | #2 |
Combined Applications Group
1059
Rep 680
That's crazy! Never heard of that
So far on track I have chewed through 7 sets of front pads and 3 rears (hawk HP Plus) with oem backing plates (thin metal thing) never have my pins backed out. I have not swapped them for new, reusing oem. Are you inserting them in with a light hammering? Maybe the brass bushing is super deformed and you may need new ones.
05-19-2021, 12:21 PM | #3 | |
10743
Rep 3,690
Those two are more likely your issue than anything else. |
05-19-2021, 12:40 PM | #4 |
21117
Rep 20,741
Drives: 2021 911 turbo
Might be the time to get new pins...
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
05-19-2021, 01:14 PM | #5 |
528
Rep 855
ok I just checked the caliper.. both got released from the two holes but at least the spring is still there and the pins didn't fully release.
I'll just buy new pins ($40 a pop - BMW tax) and a new spring |
05-19-2021, 01:16 PM | #6 |
528
Rep 855
05-19-2021, 01:17 PM | #7 |
10743
Rep 3,690
05-19-2021, 07:05 PM | #8 | |
172
Rep 392
FaRKle!4017.00 |
05-19-2021, 08:14 PM | #9 | |
528
Rep 855
05-19-2021, 09:46 PM | #10 |
172
Rep 392
I have used Centric with other Brembo calipers to great success, I tried Dynamic Friction once and I would not be shocked if they came out of the same factory as Centric.
Make sure you hammer the pins in there. Delicately and precisely, of course. But they're a friction fit. |
05-20-2021, 04:34 AM | #11 |
18708
Rep 14,115
Drives: G82 M4C X-Drive
This is one of my worst fears! I always double check the pins are in all the way and seated in the tensioner clip properly. The clip should seat in the groove of the middle of the clips.
Also, make sure they are actually holding tension, maybe they are worn... or even backwards! Make note of how much of the head of the pin sticks out the face of the caliper. When the pin is set completely, they should almost be able to ever-so-slightly wiggle in place if there is no tension on them. Unfortunately, you can only check this way for the first pin, since there will be tension once the second pin is in.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
05-20-2021, 07:12 AM | #12 |
1618
Rep 2,161
Any chance you have one of the rear pins trying to go up front? They'll reach but they won't stay and iirc only a few mm shorter so could happen if you didn't keep them separate
05-27-2021, 09:46 PM | #14 |
Rep 23
Yeah. It happens, normally it's just one but last time out at the track both popped out of my right rear - that was interesting, luckily got the car in before any harm. I carry a full spare set, which is unreal.. what is so hard about a simple bolted bridge?!
05-27-2021, 09:54 PM | #15 |
528
Rep 855
that what happens if you're running track pads with large retaining holes (where the pins slide through). The cheap plate spring doesn't really do much. Such a crappy design. Obviously there's no chance of running aggressive pads on the street either as they squeel enough to split your ear drums since the pads move around so much.
What do you expect from a set of calipers are that are multi-purposed across the f30 and other vehicles. BMW just thinks they can upgrade the rotor, paint the caliper blue and call it a day. |
