05-19-2021, 10:15 AM | #1 |
60
Rep 134
Switching front camber from street to track setting?
So I did my first track day last weekend with the plain-Jane summer tires that were on my car and whatever stock alignment settings. I am thinking about grabbing a separate track tire and rim set for track days and adding front camber plates to go with it. My question is is it easy to switch between street and track camber settings? I would want to run street camber when I'm just on my regular summer/winter tires but switch to more negative track camber when I switch to my track tires for a track day. From the research I've done, it looks like I can go to an alignment shop, use a marker to mark the position of the street settings, have the shop align for track settings, and mark that position as well. Then at the track, loosen the plates, move to track settings, and tighten. And at end of day reverse. I know too much camber change can mess with toe but not that much, right? Especially if I'm only moving to ~-2.4 degrees up front for track.
Are all camber plates easily adjustable to move from street to track settings? Or are some better than others for this? Thanks! |
05-19-2021, 10:29 AM | #2 |
///M Powered for Life
11490
Rep 10,329
It is definitely possible, I've been doing that for years.
If you align to -3 camber with 0.4 degrees of toe out (track setting), then ask them to go removing camber until you get to 0.3 degrees of toe in (street setting), now you can move between them at will. The 'street' setting will be around -2 camber, which is perfectly reasonable and allows you to drive 10k without any strange wear |
05-19-2021, 10:55 AM | #3 |
10743
Rep 3,690
Tbh, -2.5 front is a pretty solid set it and forget it camber for a dual duty car. The wear is relatively mild on the street.
If you want to go REAL aggressive on track camber then it would make sense to switch back and forth. |
Jamongkad239.00 |
05-19-2021, 11:16 AM | #4 |
60
Rep 134
That's kind of what I thought, but since I'm changing tires, why not change camber? Why bother having even relatively mild inside wear on the street if it's easy enough to change back? If it's annoying or a nuisance to change back and forth then I could definitely leave it at -2.5 and forget it.
05-19-2021, 11:20 AM | #5 | |
7602
Rep 3,604
1. Set the initial alignment to -3 camber & 0.4 toe out and lock that as the "out" position 2. Then move the camber in until toe is 0.3 toe in and lock that as the "in" position Thinking about how to communicate this to the shop once I eventually pick up some plates. It's really just in case I am not able to get to a shop that has experience with track oriented suspension/alignment so just want to cover my bases.
Current: F80
Prior: F82, F32 |
05-19-2021, 11:37 AM | #6 | |
11490
Rep 10,329
Once you get to -3 and total toe out 0.4, you mark that as your track setting. Toe is no longer touched. The next step is to go removing camber which affects the toe (although you are no longer adjusting toe, just measuring what happens) and you keep removing camber until toe moves from total toe out 0.4 to total toe in 0.3. At that point, your camber is around -2 and the plates are marked a second time. From then on, you just move camber by jacking up the front and take it from one setting to the other. The toe out track setting is very desirable on front engined/rwd cars |
RugbyBro7601.50 |
05-19-2021, 12:19 PM | #7 | |
10743
Rep 3,690
What tracks do you frequent? |
05-19-2021, 12:58 PM | #8 | |
60
Rep 134
Track-wise, nothing frequented yet I've only done one at Raceway Park of the Midlands near Omaha, NE. It's the closest track to me but still just over 2 hours away. Other track are 4-6 hours away (I'm in Des Moines) |
05-19-2021, 01:10 PM | #9 | |
10743
Rep 3,690
Try -2.5 for a little bit, I'm fairly confident you'll be very happy with it on a dual duty car. All that extra crap and adjustments would take away from the fun stuff for me. |
05-19-2021, 01:23 PM | #10 |
77
Rep 353
I just get my alignment done. Have Vorshlag camber plates. With minimal camber allowed is around -2.0 degree and +2mm toe in. With -3.0 degree negative I get zero toe. Please easy to change at the track. Just make sure both front wheels are off the ground so there is not torsion on front and make easy to slide the plates.
05-19-2021, 01:27 PM | #11 | |
11490
Rep 10,329
05-19-2021, 01:29 PM | #12 |
10743
Rep 3,690
05-19-2021, 01:34 PM | #13 | |
11490
Rep 10,329
I have to swap wheels anyway, so the wheel is going up in the air no matter what |
05-19-2021, 01:39 PM | #14 |
10743
Rep 3,690
Before I got the APs, I had to show up 30 minutes earlier just so I can bleed my brake system before each day. Remembering that makes me cringe in pain...
SYT_Shadow11490.00 |
05-19-2021, 01:41 PM | #15 | |
11490
Rep 10,329
So... does it take 30 minutes with or without your cool IG selfies? Lol |
NYG10742.50 |
05-19-2021, 01:43 PM | #16 |
10743
Rep 3,690
Haha, no selfies. I'm a slow mover in the mornings.
05-19-2021, 02:04 PM | #17 |
60
Rep 134
Does only one wheel need to be up at a time? So to adjust the left front camber plate, only the left front tire needs to be off the ground? Or do both front tires need to be off the ground?
05-19-2021, 02:04 PM | #18 |
11490
Rep 10,329
I only take one side off the ground at a time
05-19-2021, 02:10 PM | #19 |
1107
Rep 1,301
This season I began doing the camber switch as well, and can verify it's quick (one side always takes more oomph for me than the other for some reason) -- easiest way to do it, I think, is with corner up in air but with tire on, push in on the top side of tire to gain more leverage (as opposed to prying at the plate). When going from -3 back to -2, you simply loosen the bolts and physics just makes the plate slide back to -2 with no effort on your part.
Another vote for Vorshlag plates. At my current ride height, the adjustment slider is at -2 on one end and -3 on the other (but that's basically the max negative). My gripe with the GC plates is that to achieve this adjustment range I would have had to flip the slider bolts back and forth (street vs race position). The Vorshlags have a much simpler overall design and for me I just need to loosen and slide without any other drama |
05-19-2021, 02:11 PM | #20 | |
11490
Rep 10,329
05-19-2021, 02:12 PM | #21 | |
10743
Rep 3,690
05-20-2021, 08:26 AM | #22 | |
60
Rep 134
What's the min and max threshold on the Vorshlag plates? Sounds like -3 is max for your ride hide. What's min? (though I guess min could actually be -3 since it's a negative and max the other way ) |
