05-14-2021, 09:50 PM | #1 |
55
Rep 236
Bavgruppe Rings Install Questions
So I just got both myheadlights apart and got that butyl seal out as good as I can without going overboard (what a pain in the butt). I got the white Vision rings and White switchback brows and have a few questions.
1) I want to use the brow as my turn signal. It has that yellow wire that says "to turn signal power" comming out of the driver. Where does this go exactly? it looks like it should be soldered or spliced into something. there are two turn signals already existing in the light from what I can tell (the bulb and the small LED in the corner) so IDK exactly where to splice that in. 2) If i make my brow the turn signal should I no longer use the bulb turn signal that is already in the light? If I remove that won't it throw a code? I would prefer not to code the car again to save money if that is nessary to remove the bulb turn signal. 3) There are a TON of wires, drivers, power device, and capacitor for the rings and brow. Where do these go exactly? should I just shove them all in the back and make them fit or is there a process to neatly lay them out in the headlight? Thanks!! |
05-23-2021, 06:21 PM | #3 |
222
Rep 1,254
That wire is only relevant if you are installing led brows or if you want your halos to "switch" to amber when turning. Otherwise just leave it.
If you need more help pm. I'll give you my number and I can walk you through it. Last edited by patroklai; 05-23-2021 at 10:09 PM.. |
05-24-2021, 07:23 AM | #4 | |
55
Rep 236
It turned out ok but Im sure it would of went much quicker if there were actual instructions and not like 3 pictures on a document of random unmodified headlight parts telling you to trim like this (like wtf?!?!). Im sure much more sales could be made if there was an actual good tutorial/instructions that would allow for less mechanically inclined people to complete this job with confidence. |
01-30-2022, 10:31 PM | #6 | |
57
Rep 149
Drives: BMW M3 E92
01-31-2022, 08:54 AM | #7 | ||
55
Rep 236
01-31-2022, 09:40 PM | #8 | |
57
Rep 149
Drives: BMW M3 E92
I closed up my headlights without testing or anything because I was stubborn and waited until it was all buttoned up for the reveal... |
02-01-2022, 09:57 AM | #9 | ||
55
Rep 236
