05-10-2021, 10:38 AM | #1 |
7602
Rep 3,604
Helmet recommendation
So I rented a helmet for my first track day, and as I’ve decided I want to do this more often I figured I should pick up a helmet. There’s a lot out there even in the $500 or less bracket. Some things I noticed about the rental helmet (unknown racequip model)
1. Fairly heavy, felt like 4-5 lbs. Would love something slightly lighter but not a massive deal - I’ll just work out neck a little more 2. Felt like I had very little head room with the headliner with stock seats lowered all the way down. I had to sort of slouch a bit, otherwise if I was straight up / full spine extension, I’d be grazing the roof. I’m 6ft but quite a long / lean build for reference. 3. I wear glasses, I did okay with visibility on the day but a little more open visor would be a wishlist item. All that said I tried ordering a SA2020 Bell M8 primarily for the brand rep and large visor section, but they’re sold out with unknown ETA. So with that, does anyone have any recommendations at what to look at / for?
Current: F80
Prior: F82, F32 |
05-10-2021, 10:57 AM | #2 |
13524
Rep 8,165
Someone more experienced might know this better than me, but I am not sure how safe wearing just a helmet without any sort of HANS device actually is. Especially in a car with so many airbags and no front cage.
Had to wear a helmet once and due to the integrated head restraint that curves forward on the stock seat, my head was pushed forward a bit too much. Would have had to lean the seat back, but I like to sit more upright. No issues with headroom at 6'2, but I have a sedan.
05-10-2021, 11:06 AM | #3 | |
7602
Rep 3,604
Current: F80
Prior: F82, F32 |
05-10-2021, 11:13 AM | #4 |
10744
Rep 3,690
The best helmet will be the one that fits comfortably. Every company fits differently.
I'm 6'2 - LOVE my Super Bandit https://www.summitracing.com/parts/sim-6210008 |
///Mani36.00 |
05-10-2021, 11:56 AM | #5 | |
13524
Rep 8,165
05-10-2021, 05:26 PM | #6 |
///M Powered for Life
11490
Rep 10,329
I have a Stilo, had a Bell prior to that. Whatever your budget is, make sure you try it on and keep it on a solid 30 minutes. All melons are not the same, so what works for me may not work for you.
My current Stilo is ~1k, next helmet will be the $2.7k version that has FIA approval. Melons are valuable! Find a place that has several and sit down and relax while trying them on. Make sure they meet the latest approval standard |
RugbyBro7601.50 |
05-10-2021, 07:12 PM | #7 |
2182
Rep 1,665
I have an Arai GP-5W which I like a lot, very comfortable. I went through 3 or 4 helmets before finding the Arai. Bell in particular are very round and put pressure on my forehead. Arai are more oval shaped. Find a race shop and try them on, or order a few different options from a place with free returns so you can try them on at home with no pressure.
RugbyBro7601.50 |
05-10-2021, 07:53 PM | #9 |
759
Rep 950
Here's what I'm using, nice helmet and lightweight too.
https://store.windingroad.com/Bell-R...-Helmet-SA2020 Schroth SHR Flex Head Restraint, works well. https://store.windingroad.com/schrot...pt=With%20Pads Added a smoked visor as its extra. https://store.windingroad.com/bell-r...ent-faceshield And definitely buy this to kill the funk lol. https://store.windingroad.com/molecu...er-4oz-sprayer Bought them @ Winding Road in Sonoma. That's the best, go there and try them all, happy hunting
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf Last edited by Wanted_M; 05-10-2021 at 08:07 PM.. |
RugbyBro7601.50 |
05-10-2021, 08:08 PM | #10 | |
7602
Rep 3,604
Current: F80
Prior: F82, F32 |
05-10-2021, 08:14 PM | #11 |
759
Rep 950
Lol yeah, fat fingered it
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
RugbyBro7601.50 |
05-10-2021, 11:37 PM | #12 |
255
Rep 295
I'm about to try out a Gforce rift carbon. I have it on order from saferacer
Previously I had the cheapest thing money could buy which was a Gforce Pro Eliminator SA2010 which was also totally fine and I have had it for 10 years without major complaint. I'm just trying to find something a bit lighter but overall I like the Gforce full face just fine. I have a pretty typical "large" head. |
05-11-2021, 10:49 AM | #13 |
533
Rep 1,415
I'm looking to replace my helmet as well. I have a Bell M4 SA 2010, which funny enough, SCDA somehow let me run this year for two events despite their emails to run SA2015 and higher. One of the techs also did an actual check and didn't say anything which I found odd. I thought the M4 was SA 2015 which is why used it; apparently theres a yellow sticker on the inside which identifies the SA spec.
Anyway, what's the deal with the carbon fiber helmets? They weigh like 0.5 grams less than regular helmets at 4x or high the cost. I saw a windingroad top 10 helmets article yesterday which shows weights of their top ten, and the regular helmets are basically the same weight. Last week at WGI I picked up a carbon Stilo and a regular Stilo at the Little Speed Shop store, I'm guessing the $1000 model, and found no difference in weight. I want to likely go with a SA2020 Arai or Stilo at around $1000, but are they any better than a $500 Bell M8? The winding road comparison states the M8 has better visibility with the bigger visor which is evident by comparing photos of the various helmets, so that's a plus for me. I also found an interesting forum post yesterday listing the helmet preference of 2018 F1 drivers. More than half use Bell helmets, second most was Arai, then Schuberth, and last Stilo with like 3 drivers. I mention this because reading various forums, people all seem to recommend Stilo for some reason so I want to know why. |
05-11-2021, 04:53 PM | #14 | |
759
Rep 950
https://smf.org/testing https://smf.org/standards/sa/2020/SA2020_final.pdf FAQ from Snell; Helmet price is not an indication of protective capacity. Although there are Snell certified helmets in different price range, all Snell certified helmets meet the Snell test requirements. In addition to protective capability, other features on a specific helmet, such as graphic design, unique shell and liner combination for different head size, and improved fitting for different head shape, can add a lot to helmet manufacturing cost. Snell standards don’t consider issues like weight, bulk, ventilation, noise reduction, comfort, style or fit quality. You can tell us about these better than we could ever tell you. Shop carefully; a $150 dollar helmet you won’t wear is no bargain.
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf Last edited by Wanted_M; 05-11-2021 at 05:01 PM.. |
05-11-2021, 05:11 PM | #15 | |
10744
Rep 3,690
05-11-2021, 07:43 PM | #16 |
412
Rep 737
It is all about fit. For me, I wear a Bell GP3. My wife used to wear a Simpson Bandit and absolutely loved it. However, alot of people are going to Stilo not because it fits, but because the integrated electronics are so convenient.
The pricier the helmets the better the "features" are. Removable and washable padding, anti fog visors, better air flow, etc.
05-15-2021, 10:53 AM | #17 | |
25
Rep 98
I've added wiring for ear buds (helps with the race car volume) and a tinted shield. |
05-15-2021, 12:28 PM | #18 |
7602
Rep 3,604
I ended up picking up a G Force Nova. It was the most comfortable of all the helmets that were available - emphasis on available as many sub $500 options were out of stock and seems like they will be for a while
Current: F80
Prior: F82, F32 |
Wanted_M759.00 |
05-15-2021, 08:19 PM | #19 |
5462
Rep 5,154
I just picked this up so I can go to the drag strip. It's only 1 pound and fits my bean pretty snugly. Someday I'll try a Bell M8 Carbon but this one looks identical for $350 less. It's not the newest Snell rating but it'll get me 3-5 years until it runs out (2010+ is currently required at Maple Grove).
I'm 6'2" and with my F80 standard seat fully lowered my helmet doesn't bump the headliner. I wear glasses and can easily get them on/off and hands inside the lifted face shield to adjust them. I haven't tried my big polarized Ray Ban sunglasses yet. Conquer Carbon Fiber Full Face Auto Racing Helmet Snell SA2015 https://smile.amazon.com/dp/B01NALI6...UTF8&psc=1
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
05-17-2021, 08:44 PM | #20 |
533
Rep 1,415
I ended up buying an Arai GP7 and it's too small in size large. I wore a Medium with Bell. The eye opening is also so small compared to my Bell.
Returning it as the GP7 isn't even available in XL. Anyway, will give Stilo a try, and if that's not available, will go back to Bell. As mentioned earlier in the thread by others, I've found out that Stilo and Bell are all backordered. Bell is 8 to 12 weeks and Stilo 4 to 6 weeks at saferacer. Going to reach out to some other sites to see their availability of Stilo tomorrow. |
05-17-2021, 08:55 PM | #21 |
7602
Rep 3,604
Another update... going to return the G Force this weekend. Comfy helmet but build quality is quite poor. The adjustable padding is held in with velcro and the actual velcro strips and spots have detached from the helmet... so some of the pads would only be held in by pressure from my head -_-
Current: F80
Prior: F82, F32 |
05-17-2021, 09:16 PM | #22 | |
412
Rep 737
