KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
10-29-2008, 08:59 AM | #1 |
Rep 21
Low Tire Pressure Warning
Took the M on a road trip from NYC up to Syracuse this past weekend - fantastic fall drive. When I started it up on Saturday morning (after sitting outside on a cold night) I had a warning that all 4 tires were low. On visual inspection they all looked fine. I drove around a bit - checked the pressure (which was fine) and reset the TPMS with the button on the dash - warning went away and didn't come back.
I'm assuming it was compression due to the cold air, but wanted to see if this has ever happened to anyone else? -Todd 2008 E90 M3 - Jerez/Silver - Loaded |
10-29-2008, 09:05 AM | #2 |
37
Rep 1,413
You are 100% correct. The sudden drop in temp will affect your tire pressure. It is better to check/adjust the tire pressure during the start of the cold season.
10-29-2008, 03:01 PM | #4 |
Rep 146
Happened to me yesterday too. I figured it was due to the cold weather. Thanks for the reassurance.
e92 M3 Jerez Black, Fox Red Interior, Heated Seats, Satellite Radio, 18's |
10-29-2008, 06:19 PM | #5 |
1644
Rep 2,775
Drives: F95 X5MC
Same thing happened to me. BMW Service Dept said it was because of the cold weather.
Edit: I just checked my tire presure, and fronts were about 7 psi under, rears 5 psi. I used the M Mobility air cimpressor in the trunk...very cool!
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
Last edited by AwesomeM3; 10-29-2008 at 06:49 PM.. Reason: Checked tire pressure |
