03-30-2021, 04:31 PM | #1 |
Rep 18
Apple Carplay input slow
Hi all - Just wanted to know if this is normal. I just got Apple Carplay activated on my 2018 F80, everything connects as expected and I can use Carplay wirelessly. The issue I am having is that there is about a 2-3 second lag between me putting in a command such as pause/play/skip, before the action takes place. Is this delay what you all are experiencing? Normal? I don't have any other issues, just the input delay which is driving me nuts. I tried deleting/removing the paring with the phone from iDrive as well as from the iPhone (BT and Carplay), with no luck.
- I have iPhone 12 with latest update 14.4.2. - iDrive is update date as of today. These are the software/firmware I currently have installed: NBTevo_O18184I Telephone: TB-006.025.001 Media: MB-006.026.050 HMI: HB-006.026.050 Last edited by DaRox; 03-31-2021 at 09:02 AM.. |
03-30-2021, 06:10 PM | #2 |
BimmerPost Supporting Vendor
1792
Rep 3,057
Hi,
drop me your VIN - I'll check if you have WiFi antenna.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
03-30-2021, 10:41 PM | #3 | |
151
Rep 548
03-31-2021, 03:54 AM | #5 |
1792
Rep 3,057
New software could fix the issue
03-31-2021, 09:06 AM | #7 |
1792
Rep 3,057
Usually works fine on this software version. Try to reset your network settings in iPhone.
03-31-2021, 09:28 AM | #8 |
Rep 18
03-31-2021, 11:31 AM | #9 |
Rep 18
03-31-2021, 12:53 PM | #10 |
908
Rep 1,044
Did you confirm if you have a Wifi antenna or not? That will have a huge impact on performance.
Rob | instagram
2020 F97 X3 ///M Donington Grey 2018 G01 X3 xDrive30i Alpine White Previous: 2016 F82 ///M4 Black Sapphire Metallic | My Build Thread |
03-31-2021, 01:05 PM | #11 |
Rep 18
03-31-2021, 01:09 PM | #12 | |
Rep 18
This is the exact one I installed: https://www.ecstuning.com/b-genuine-...n/61119278133/ |
03-31-2021, 03:59 PM | #13 | ||
908
Rep 1,044
It's possible the antenna could be relocated for better performance. I would check the firmware versions etc as that may be the solution and easier than pulling the dash apart to relocate the antenna.
Rob | instagram
03-31-2021, 04:28 PM | #14 | |
Rep 18
Firmware version for the antenna? I posted the firmware and software versions above for iDrive. |
03-31-2021, 06:41 PM | #15 | ||
908
Rep 1,044
Rob | instagram
03-31-2021, 09:17 PM | #16 |
Rep 18
04-04-2021, 06:22 PM | #18 |
Rep 18
04-04-2021, 06:45 PM | #19 |
1792
Rep 3,057
Probably newest one which is NBTEvo_X
04-04-2021, 06:47 PM | #20 | |
718
Rep 1,248
Road Map North America 2017-1 NBTevo_L172521 Tel: TB-006.003.050 Media: MB-006.002.050 After Road Map North America EVO 2020-3 NBTevo_X20511I Tel: TB-007.030.001 Media: MB-007.030.001 Hope it helps, I'm still under warranty and had to go for an exhaust flap failure. So I told them my Nav was acting up also (unstable and slow) which is kind of true and they updated it. But it will reset everything. You will probably have to pay if you are out of warranty. |
04-05-2021, 03:42 AM | #22 |
1792
Rep 3,057
Nothing relevant for BMW beside Fullscreen being able to just code.
