03-23-2021, 10:58 PM | #1 |
60
Rep 56
Front Sway Bar End Links Hitting Uprights
Hoping someone has encountered this issue before and has a fix for it...
Installed on my car is the following: - Ohlins R&T - Ground Control Street Camber Plates - Hotchkis Sway Bars Car is fairly low but not "mad tyte jdm yo" low. When the suspension work was completed we discovered that the OEM end links were too long to be re-used, we then sourced a set of shorter E46 M3 front end links as a temporary solution. After installing the E46 M3 links we found that the end links made contact with the upright strut clamping bolt and the ABS/Brake line bracket... our monkey brains decided the best solution was to add some shims and bend the links to create clearance, we then ordered a set of PSI end links in the correct length hoping that their design might get us the clearance we need from the upright. Today we finally took a look at whether or not the PSI end links we purchased would provide sufficient clearance, they do not (unsuprisingly), so I'm now considering ordering a set of end links with longer threads so that I can run a 20mm spacer between the end link and the mounting clip on the strut body. It's worth noting that it does not matter which position we have the sway bar in, there is contact in all four configurations. Has anyone else ran into this issue before???? I searched and found nothing, at first I blamed the install shop but after looking over the car myself, it does not appear as though they installed anything incorrectly. Anyone??? It seems to me that turning the strut more towards the inside is the only possible solution? Is it possible my shop is so stupid that they couldn't figure this out??? Last edited by jasonturbo; 03-23-2021 at 11:05 PM.. |
03-24-2021, 07:33 AM | #3 |
207
Rep 242
It looks like the strut should be turned more towards the car to clear the upright bolt. At least that's how the OEM strut is positioned. Attached pic is borrowed from Bill's H&R spring install DIY (driver side).
http://billswebspace.com/M3HRSpringInstallation |
03-24-2021, 08:03 AM | #4 | |
3953
Rep 3,992
03-24-2021, 09:18 AM | #5 | |
just another M3
514
Rep 1,152
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
03-24-2021, 12:25 PM | #7 |
130
Rep 935
I happen to have almost exactly the same shot of my Ohlins install and it does indeed show that your Ohlins shock seems to be clocked incorrectly.
Pic attached. Just noticed that the pic gets rotated when attached on here, not sure why. The original is the correct way up.
03-24-2021, 02:32 PM | #9 | |
130
Rep 935
I'm interested to see how low you went where the E46 end link is an appropriate length. Thanks Az
03-24-2021, 04:00 PM | #10 |
60
Rep 56
Pics attached, you can see more pics of the car on my IG @jasonturtle there is a highlight reel with lots of pics.
I don't why the second image rotated... m3post issues. I believe that the center to center front end link measurement with the car this low was 210mm. |
911r891.00 |
03-25-2021, 02:50 AM | #11 | |
130
Rep 935
Thanks, the arch gap on yours makes it looks like you're running the recommended settings in the Ohlins manual, but I guess your tyre is smaller than a 245/40/18 which would be on there for standard 18s? And the thread showing on your front shocks makes it look like you are running 25ish mm lower than the recommended settings. If however you are at the recommended settings +/- 15mm then the standard E92 end links will work fine - I'm running 15mm below recommended settings and using the standard end links. Hope you get it all sorted out
