03-08-2021, 07:44 PM | #1 |
82
Rep 280
Suspected brake fluid leak after track
Hi everyone,
I'm back on the forum after a hiatus of several years, with a brand new to me 2017 M4 competition (I used to be on here with my 2015 M4). I took it to the track for the first time this weekend (Summit Point in W. VA) and had a blast. Learning from past mistakes and from all the advice on this forum I installed Pagid RS29 pads and dedicated track wheels (Nitto NT01s, staggered 275/305 setup). When swapping brake pads I had slight leakage of brake fluid from the reservoir (which I understand sometimes happens when moving the pistons) - also had the cap unscrewed. It was very little and obvious to me what happened so I paid it no mind. The car behaved amazingly on track, I rejoiced in the new brakes and tires, and was able to push the car harder than previous times. On my very last session I had brake fade, which I chalked up to either stomping on the brakes excessively or boiling my stock brake fluid. I plan to do a flush with castrol SRF this week just in case. The morning after returning home I took the car out for errands and later that day saw a much larger leak of what I believe is brake fluid under the car, coming from somewhere in the middle of the undercarriage, just behind the front wheels. It has the same consistency and color as the brake fluid so I'm wondering if I sprung a leak somewhere. Has anyone experienced this or have some advice? I checked the forum and while there have been plenty of posts on brake fluid reservoir leakages while swapping pads, I haven't seen anything matching this case... Thanks in advance, and greetings to all the old friends on the forum! Last edited by Mortis; 03-08-2021 at 07:51 PM.. |
03-08-2021, 08:38 PM | #2 |
/M Enthusiast
1599
Rep 1,619
I have never seen that on 2 M4 that I have tracked. Is it possibly brake fluid that leaked from over filling the reservoir?
I have always flushed the stock brake fluid with SRF before tracking a car.
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune Last edited by Suds; 03-08-2021 at 08:44 PM.. |
icegrill2078.00 |
03-09-2021, 12:09 PM | #5 |
10744
Rep 3,690
Did the level in the master fluid reservoir drop?
Did you over tighten the bleeder and strip it maybe? (Real easy to do) The hard line is visible in the back/top of the wheel well so you should be able to trace it. It's not likely that you're leaking before that so leave that for last. |
03-09-2021, 09:39 PM | #6 |
82
Rep 280
Thanks everyone. Turns out the fluid I found the day after my return from track was the original fluid from when I swapped brake pads. In my haste to get out the door I forgot to clean it and thought it had evaporated, which of course it had not. Now I feel like an idiot...
Imhighonboost0.00 |
03-10-2021, 07:10 AM | #7 | |
1107
Rep 1,301
03-12-2021, 12:28 AM | #8 | |
965
Rep 5,032
Glad you remedied this. |
03-12-2021, 07:45 AM | #9 | ||||
82
Rep 280
03-12-2021, 09:33 AM | #10 | |
10744
Rep 3,690
Overtime, I'm starting to realize that my forward rake was probably a bad idea on the M4. |
03-12-2021, 10:20 AM | #11 | |
172
Rep 392
Braking less means converting less kinetic energy into thermal energy because, well, you're slowing the car down less. Most people who aren't pro race drivers brake too much. Also, braking harder for shorter time might convert the same amount of KE to thermal energy but if you do this over less time you have more time to shed that heat and manage it. |
03-12-2021, 01:17 PM | #12 | |
10744
Rep 3,690
It's true but it's not because they're braking earlier and lighter. They're braking later and harder, the difference is that they enter corners faster so there's less work being done by the brakes resulting in less heat. |
