02-27-2021, 08:27 PM | #1 |
315
Rep 168
Square tires, staggered wheels
2013 128i base. Style 262 stock staggered wheels. 225-45-17 tires all around. Can these be straight up rotated, or do I need to dismount and remount and keep wheels where they are?
02-28-2021, 08:18 AM | #2 |
1Addict
3234
Rep 7,894
Highly recommend rotating tires only.
MightyMouseTech4337.50 |
03-07-2021, 04:28 PM | #3 |
185
Rep 505
Drives: 2010 128i 6MT Sport Pkg. 18"
I had a square tire setup on staggered wheels. You can rotate side to side to change the direction of rotation and increase tire life, but not front to back.
03-07-2021, 06:44 PM | #4 |
59
Rep 96
Same size tires. Same offset wheels. Small wheel width difference, but both within acceptable range for the tires.
Sure it's not the 'ideal'. But if it's what you have to work with, save your dismounting and remounting money towards a set of square wheels and just normal rotate them in the mean time. The real world difference should be negligible. |
