02-20-2021, 09:01 AM | #1 |
179
Rep 331
Staggered vs Square for track dedicated wheels?
Hey guys, looking for some guidance on a dedicated track wheel/tire setup for my M3 comp. I'm going to run my first couple of track days on the stock 666m wheels with stock tire sizes to get a feel for the car. But eventually I'd like to switch to a dedicated track setup. I'm leaning towards a set of 18's in either EC-7's or SM-10's, but I can't decide if I want to go square or keep a staggered setup.
On my previous 335i track car, I ran with the stock 225/255 staggered setup. But from what I've read a lot of guys prefer to swap to a square setup for a more neutral feel. My concern with the F80 is rear grip. Staggered means I could run 305's in the back compared to something like a 275 square setup. Think the added grip is worth going staggered? Or is the more neutral feel on track worth the trade off?
2017 F80 M3 - Mineral White/Amaro Brown
2003 E46 M3 - Jet Black/Cinnamon |
02-20-2021, 10:43 AM | #2 |
134
Rep 257
Square setups are more for tire rotation and getting more life out of a set of race tires than about neutral feel. More tire is always better, so staggered setup with maximizing tire width is better, with the downside of not being able to rotate tires.
02-20-2021, 01:01 PM | #3 | |
179
Rep 331
It looks like Apex recommends 275/305 stagered: Front: 18x10" ET25 with 275/35-18 tires Rear: 18x11" ET44 with 305/35-18 tires
02-20-2021, 01:24 PM | #5 |
///M Powered for Life
11490
Rep 10,329
Stock wheels with sticky tires will work for a surprisingly long time. Unless you are tracking a lot and are very fast, I would just keep a dual use tire on your OEM wheels and just use that everywhere.
That said, 10.5 fits square without any issues in the F8X cars. I would not use a 10" front wheel when I can easily fit a 10.5" wheel instead. You 'can' also run an 11" up front, but the ET is different than the rear so you won't be able to rotate. I feel like a 10.5 ET36 square setup is plenty wide. If you are having issues coming out of corners, try setting the throttle to 'efficient' for a more linear feel. |
_Timm334.00 |
02-20-2021, 08:03 PM | #7 |
179
Rep 331
That's the plan in the short term, but realistically the 666m aren't an ideal track wheel. Plus 18" tires are a lot cheaper than 20's.
02-20-2021, 08:04 PM | #8 | |
11490
Rep 10,329
The electronics work fine with a square setup |
02-20-2021, 08:30 PM | #9 |
500
Rep 411
02-20-2021, 08:32 PM | #10 |
11490
Rep 10,329
I was trying to fit an insanely large michelin slick... couldn't even with a big spacer. Sad but true
02-21-2021, 08:58 PM | #11 |
69
Rep 278
