12-13-2020, 11:32 PM | #1 |
22
Rep 102
Weird errors and the Ac stopped cooling
I recently added the carplay module maybe i messed up a wire in the dash?
everything work, on the display Vented seats light up but don't work and the ac does everything but blow cold its a 2015 m6 here are the erros |
12-14-2020, 01:07 AM | #4 |
178
Rep 274
I just replied to a thread on the F10 5 series forum about errors with the climate/radio panel after CarPlay MMI module install. After seating the blue cable properly, I got power back to my climate/radio panel. But now I am also getting the same errors in IHKA (8011AF, 8011B1, 8011B3, 8011B5, 8011B7) and in ZGM (801C20).
I had an issue seating the blue connector on the back of the climate panel as it would move in and out even when locked. I had powered up the car and found the climate to lose power when the cable was moved. After playing with it a few times, I got it to seat properly. But when the cable was loose, the A/C system and the climate panel would turn on and off. I am worried something got messed up when this happened. For me, these errors return immediately even if I clear them. Which CarPlay module did you install? I installed the Andream MMI unit. I actually removed a Carlinkit unit and replaced with the Andream unit but I never had these problems when I installed the Carlinkit the first time.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #578262 as a referral.
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i Last edited by GrabacrOne; 12-14-2020 at 02:52 AM.. |
12-14-2020, 01:14 AM | #5 | |
22
Rep 102
I have the Andream I just pulled the ac out again and going to re attach everything |
12-14-2020, 02:05 AM | #6 |
King of NYC
118
Rep 176
I also had climate control issues after the MMI install. It didn't act up right after the install, maybe a couple of months later. So I didn't put one and one together and link the source of the issue to the MMI install.
For one thing, my HVAC was not blowing cold air and there was no fan speed control. It would just turn on/off at low speed, that's it. Weird thing is the rear climate control fan control worked fine. Later the fan stopped blowing all together and the HVAC screen was blank. First culprit I thought of was a blown fuse. Checked all fuses, all intact. Later my fan would stay on nonstop even with the car off. No heat or AC, just the fan. And randomly the fan would turn back on while the car was off for extended periods. So this meant that the fan motor was still working and that was not the culprit. The HVAC display was still blank and none of the controls worked. It was draining my battery and I was paranoid that it would kill my battery. I had to park my car with a battery tender. At this point I suspected the FSU (final stage unit aka blower resistor) to be the culprit, a common issue on older BMWs. Took it to the dealer and they confirmed the same symptoms. They said they had to change the HVAC panel. I was skeptical but hey, the car is under extended warranty, who am I to complain. After seeing the price of a new panel, I said YIKES! (thanks for that warranty!) Later, I get a call back from the advisor saying it was spontaneously resolved! They tried and tried and couldn't reproduce the symptoms again so they put the car back together. I was even more skeptical now but they graciously waived my diagnostic fee and sent me on my way (5 days in a loaner for free too They said if it ever comes back they'll take care of it. It's been a year now, zero issues since. I've now realized that the cause HAD to have been the MMI install! I must have dislodged a connector or inadvertently knocked something out of whack. The only other occasion the dash panels had been disassembled after the install was at the dealer. So they must have adjusted everything back as it should have been. I'm just glad they didn't notice my MMI unit! You know they would have definitely denied my warranty claim with that and rightfully charged me the diagnostic fee. Lol. So lesson learned. After your MMI install, make sure to check your HVAC, navigation and audio functions thoroughly. Any monkey business going on with any of those systems afterward should be attributable to the MMI until proven otherwise. Once ruled out, then look at the stock OEM components/wiring. And I'm the one usually telling others about Occam's Razor. Lol. I've owned older BMWs so my mind has been poisoned to assume that electronic gremlins are common to BMWs and are to be expected as a consequence of ownership. Bad assumption. This car has turned out to be way more reliable than I've expected and the ones I've owned in the past.
2014 BMW M5 Competition
MCB on Silverstone |
12-14-2020, 02:49 AM | #8 |
178
Rep 274
Did this clear the error codes in IHKA and ZGM as well?
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i |
12-14-2020, 03:10 AM | #9 |
22
Rep 102
12-14-2020, 03:14 AM | #10 |
178
Rep 274
Ok great! Will give it a shot again and update. So the latch should be set all the way down (away from the wires) before plugging in and moving up to lock?
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i Last edited by GrabacrOne; 12-14-2020 at 03:30 AM.. |
12-14-2020, 03:44 AM | #11 |
22
Rep 102
12-15-2020, 03:06 AM | #12 |
178
Rep 274
Went through and reseated all the connectors and I was able to clear the errors in IHKA. The one error in ZGM (801C20) is still there but maybe this will clear on its own eventually since it's related to the error memory. Is this one still recurring for you?
12-15-2020, 11:44 PM | #13 | |
22
Rep 102
YES , that is my belief also . That the memory is full and will clear up on its own |
06-30-2021, 03:38 PM | #14 | |
Rep 1
WOW...Thanks, i had no cold air and AC blowing just hot air...compressor/clutch was not engaging. This happened after i installed after-market backup camera. Took the climate control panel out again and reseated the "BLUE" tab...voila!...ac cold air back! |
07-13-2021, 11:34 PM | #15 | ||||
22
Rep 102
07-15-2021, 01:26 AM | #16 |
Rep 1
Same problem, black connector
Just installed an MMI for CarPlay in my 2015 535i today and had problems with no A/C or heat after putting everything back together. Did a whole lot of research and checked a whole lot of fuses after compressor clutch was not engaging. Checked the blue clip on the back of the climate control unit and everything was fine there
checked the black clip and the blower kicked on automatically once I pushed it in a little more. Had to do a bit of wiggling but heard one final click as I reattached it one more time and A/C came back. Moral of the post, if its not the blue one, check the black one.
