M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      12-11-2020, 12:20 PM   #1
drifter17a
Drives: bmw
M5 f10 decat
All,
does removing M5 f10 cat cause any issues apart from engine light?
Friend of mine has done it and no engine light but lots of error re fuel trim in info memory .
some posts suggests it makes the car run very lean and bust engine. i doubt if it does as engine can calculate air using afm and feedback from o2 to adjust map
in wide open throttle they use open mode so o2 reading is not used and only in cruising / low range /close loop o2 reading is used
      12-11-2020, 01:34 PM   #2
Ickdeep
Ickdeep's Avatar
Drives: '13 F10 M5 | '15 F15 X5
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
I'm not sure about the exact process but I know its not recommend to run catless downpipes on a stock tune. Your friend should look into getting a stage 2 tune for this car so that the computer is setup to run with that mod.
      12-11-2020, 03:16 PM   #3
Fast.F10
Extruding Elements
Fast.F10's Avatar
Drives: 2016 BMW M5 Comp
2016 BMW M5 F10  [0.00]
A tune for certain. Isnt an SSP or similar "suggested" for any/all stage 2 tunes though?
2022 Yukon XL AT4
2016 BMW M5
2015 Ford F250 Super Duty
2006 BMW M5
      12-12-2020, 03:50 AM   #4
ajm55
52
Drives: f10 m5
I’ve run catless dps on the stock tune on and off for the better part of 2 years without any issues. AFRs are dialed in and curiously no CEL
      12-12-2020, 10:44 AM   #5
M5_Raz
M5_Raz's Avatar
514
Drives: BMW M5
Shouldn't have any problem at all. I am also planning on doing the same.
You can also buy a BM3 tune and modify your stock tune to remove the cat check. Then flash the modified stock tune back and you'll be stock with no CEL light.
      12-13-2020, 02:38 AM   #6
rockyfeller
King of NYC
rockyfeller's Avatar
Drives: 2014 BMW M5 CP
For anyone that thinks a stock tune can't be used with catless DP, any reason why?
Obviously you're not going to net gains that way but some of us just want the catless for the sound. Is there any harm done or performance loss from stock tune with catless DP?
2014 BMW M5 Competition
MCB on Silverstone
      12-13-2020, 03:42 AM   #7
ajm55
52
Drives: f10 m5
Definitely some power gain although not optimized without a complimentary tune. Much better sound. Less turbo lag. I'm not aware of any downside and would also be keen to hear whether anyone out there has experienced any adverse effects
      12-13-2020, 08:13 AM   #8
rockyfeller
King of NYC
The only thing stopping me from a tune is warranty concerns. I extended mine till 2023. If it weren't for that I'd do it in a heartbeat.
MCB on Silverstone
      12-13-2020, 04:29 PM   #9
drifter17a
Drives: bmw
same here which is why I don't remap
