10-18-2020, 03:28 PM | #1 |
40
Rep 157
Installed LCI taillights- Nothing on the trunk works now
No inner lights, no backup can, and no ability to open the trunk with a switch. Wiring harness instructions followed to a T. Haven't tried coding yet, but getting brake light malfunction light. What's the most likely culprit?
10-18-2020, 03:48 PM | #2 | |
908
Rep 1,044
The other issues, I have no idea. Perhaps someone can chime in who has done the conversion, or possibly tom @ eas
Rob | instagram
2020 F97 X3 ///M Donington Grey 2018 G01 X3 xDrive30i Alpine White Previous: 2016 F82 ///M4 Black Sapphire Metallic | My Build Thread |
10-18-2020, 09:58 PM | #4 |
172
Rep 492
Do the coding first, then come back if you are stilling having issues.
F80
Gintani downpipes/Gintani Crank Hub Fix AA midpipe paired Dinan exhaust KW V3 coilover, Forgeline wheels, Ecutek Custom Tune MS109 by Counterspace Garage , SDgarage Built |
10-19-2020, 03:59 AM | #5 |
BimmerPost Supporting Vendor
1790
Rep 3,056
Remember you may need to update your REM module too.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
10-19-2020, 02:44 PM | #7 |
40
Rep 157
I hope i don't have to update the REM, because that's beyond bimmercode. Tonight i will try using bimmercode to change over everything to LED taillights, but i have my doubts that this will fix the trunk and camera issue.
Has anyone had a similar problem where nothing worked on the trunk after wiring in LCI tails? I am so lucky i folded my back seats prior just in case- right now i can only open my trunk with the emergency pull in the trunk! |
10-19-2020, 02:53 PM | #8 |
28
Rep 71
I'm having the same issue. Trying to upgrade to LCI rear lights on my F36
I am using a harness adapter I bought off ebay to make the inner lights to work, but I can't seem to get it to work. So tomorrow I will try a complete LCI cable from BMW, if that works then the ebay harness must of been faulty. If it doesn't work, then I'm shit out of ideas. Probably end up metering the wires & tapping into whatever I need to to power the inners. |
10-19-2020, 02:53 PM | #9 | |
1790
Rep 3,056
10-19-2020, 02:59 PM | #10 | |
40
Rep 157
10-19-2020, 03:42 PM | #11 |
28
Rep 71
I'll let you know how tomorrow goes when I get my new cable from BMW. I hope it works or that's another £140 wasted.
Another member on here has reported a faulty ebay harness, he bought a complete loom from BMW = problem solved. I contacted the seller on ebay but he fobbed me off saying he's sold loads of these adapter harness's with no problems, must be installer error. I think he's got a bad batch or somet if this turns out to be the same for you also. |
10-19-2020, 03:45 PM | #12 |
8215
Rep 18,823
Drives: BMW
Make sure the connectors that were removed are inserted back and locked into place. Also check for bent pins.
karlskry40.00 bmwmdistrict908.00 |
10-20-2020, 04:53 AM | #13 |
28
Rep 71
New loom in. No coding. The inners power up! Yes! No indicators though, so...
Re-coded everything to the T again from the coding provided by UKF30 (thanks again for that) as it was coding that made everything work properly. Everything working perfect now = happy days! Now I need to recoupe some money back for this crap ebay harness but overall I'm chuffed to bits now it all finally works. Thanks to everyone who helped. Good luck in getting yours sorted, this is what worked for me. |
10-20-2020, 07:39 AM | #14 |
40
Rep 157
Well guys, i feel like an idiot.
I was rushing to button up the install Sunday morning to get home in time for the game, and it looks like the issue was i didn't fully plug in the REM module Put the trunk back together, used bimmercode for LED tails- I didn't do the full length turn signal code, as i just wanted to get the error codes out for now. It still does the bulb check, but atleast i know this wasn't a wiring issue! |
10-20-2020, 12:30 PM | #15 | |
8215
Rep 18,823
Drives: BMW
If the inner tail portions are not blinking, the REM module needs updating (Bimmercode can't do this).
