M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      10-13-2020, 10:17 AM   #1
The Dane
Denmark
112
Drives: 2015 m5 cp
Kw has at its lowest setting not happy
Hi
The shop that is installing the kw has on my m5, just send me this pucture with the front on the lowest setting.
The assured me the have folllowd the instruktion, and have made sure the perch is all the way down.
Could it be that the have put the bag springs on the front ?
Not happy with the drop
      10-13-2020, 10:18 AM   #2
The Dane
Denmark
112
Drives: 2015 m5 cp
Btw the meassured the drop and its 8mm lower the Stock cp height
      10-13-2020, 11:25 AM   #3
Lord HUMUNGUS
Lord HUMUNGUS's Avatar
Drives: 14 M5 CP, 2002 Honda S2000
I may be in the minority on this one, but that drop looks perfect. It definitely looks lower than stock height, but still more functional than being slammed. I'm not a fan of the slammed look; I hate having to look for small potholes or bumps on the road. Regardless, I hope you get the ride height that you're looking for.
Appreciate 2
      10-13-2020, 11:56 AM   #4
The Dane
Denmark
112
Drives: 2015 m5 cp
I agere it looks perfect, but my concern is that its only 18mm lower at its lowest setting, so something is not installed right
      10-13-2020, 12:44 PM   #5
Doctor_X
1158
Drives: 2015 M5 CP - 2022 M5 CS
2015 BMW M5 CP  [0.00]
2022 BMW M5 CS  [0.00]
Be sure they install everything front and rear and drive it before making judgments on where it will settle. Also - ask to be sure they final tightened the lower strut mount with the car on the ground. If those two things have already been done - then the bottom spring perch isn’t seated deep enough.
I have the same setup, and here’s a pic for reference. My wheels are 21” but the overall tire diameter is the same as yours.
Appreciate 2
Dankrupt187.00
      10-14-2020, 09:45 AM   #6
The Dane
Denmark
112
Drives: 2015 m5 cp
She sits Nice and low now, the 305's in the back looks the business 😎
No spacers btw
Appreciate 2
      10-14-2020, 11:00 AM   #7
Lord HUMUNGUS
No spacers btw
BRB, changing underwear.
      10-14-2020, 11:24 AM   #8
The Dane
Denmark
112
Drives: 2015 m5 cp
No spacers btw
No spacers btw
Is that a compliment ? 😁
      10-14-2020, 12:11 PM   #9
eesper
Drives: 2015 BMW M5
18mm lower than non comp car maybe? The competition cars are 10mm lower than standard M5
      10-14-2020, 12:16 PM   #10
The Dane
Denmark
112
Drives: 2015 m5 cp
It was only 8mm lower, but the fixed the problem and i now have 25mm more to okay with,
On a Stock m5 you have up to 35mm lowering 😉
      10-14-2020, 01:03 PM   #11
Doctor_X
1158
What was the issue?
      10-14-2020, 03:03 PM   #12
The Dane
Denmark
112
Drives: 2015 m5 cp
Originally Posted by Doctor_X View Post
What was the issue?
I send them send them you replay😉 seriously, and the did everything plus driving it before the did anything. the Said the kw specs for the spring perch according to the manuel was 32mm on the front and 50mm on the back, the changed so its 50/50 and now the specs are in line.
Not sure what to think, but now the lowering falks in line with the 35-25 specs that kw claims, and it looks like what i have seen with other cars with the has kit.
And the car drives an behaves beautifully
      10-14-2020, 08:26 PM   #13
Doctor_X
1158
Great man. Glad it turned out! Car looks outstanding.
      10-15-2020, 06:36 AM   #14
The Dane
Denmark
112
Drives: 2015 m5 cp
Snapped some more pics today 😎
Rear is lower then the front so i will raise it, but it looks 10x more agressiv then before 🔥🔥🔥
m5rosco210.50
      07-27-2023, 12:20 PM   #15
MosTunKNowN
Kazakhstan
Drives: F10 M5
looks
before kW you had competition springs ?
which specs did you make at front and at rear ?
thanks
