European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      10-13-2020, 09:20 AM   #1
BRMF82
Australia
Drives: BMW M4
Wheels to suit 27/65-18 Michelin Slicks?
Does anyone know what size rim that would fit an M4 and suit 27/65-18 Michelin Slicks? Has to be that size, its Cup Car front (an abundance of them being unused.)
Michelin tech data says it suits an 11" wheel, rim width range 9.5-11.5
Ideally running bilstein Clubsports and no body modifications - Square setup only so I can use them on all corners.
If it could also run a cup2 size that would be great, sizes available in Australia are 265/35/18 or 295/30/18.
Ideally something cost effective yet strong (track only wheel)
Thanks!
      10-13-2020, 10:35 AM   #2
Gomeler
500
Drives: '16 M235iR, '16 M4 GTS
I run 18x11 square with a 25mm spacer up front using Apex EC-7 18x11 +44 wheels. 295/30r18 Toyo RR clears the strut, fender, and liner without rubbing/contact. If the dimensions of that slick are close to the RR, buy one wheel/tire and check for fitment front and rear.
BRMF821.00
      10-13-2020, 01:55 PM   #3
jacobe92
jacobe92's Avatar
Drives: 2016 Hell Rot F80 M3
Fitment
Forgeline GTD1 Square 18x10 Et 27 Pirelli 285/645/18.
2016 Hellrot F80 M3|JRZ RS Pro with Swift Springs 550/750 spring rates l AP Radical 5000R 9668/9449 lSpiegler SS LinesI DS1.11I Eisenmann DP|MPE Catback|18" Forgeline GS1R 18x10 et 22 and 18x11 et 44 NT01 275/35/18 and 305/35/18| Forgeline GTD1 18x10et43 SquarelM Performance Lip/Splitter|IND aesthetic mods|Dinan Toe Link|Fall Line mono ball conversion kit and upper link kit| Aim Solo 2DL Smarty Cam|Simpson Hybrid|Stilo Offshore helmet.
BRMF821.00
      10-13-2020, 04:10 PM   #4
BRMF82
Australia
Drives: BMW M4
How much space do you have for the strut and guard? It's my understanding that pirelli make quite a small sick
      10-13-2020, 08:19 PM   #5
gum2012
51
Drives: m4 white 2018
Nice! Where do you buy yours from?
      10-13-2020, 09:42 PM   #6
135
Australia
113
Drives: 135i
When I last checked (around 2-3 years ago?), the Porsche GT3 Carrera/Cup cars had the Michelin N2# 27/65/18 slick fitted to a custom sized 18x10.25" (286mm wide) wheel.
The section width of one of these brand new Michelin slicks fitted to this custom wheel was 290mm and the OD was 645mm.
At that time, based on the Michelin's advertised section width of 298mm on a measured 11" wheel, the section width should have been 290.5mm on the 10.25" wide wheel (i.e. 5mm less section width for each 0.5" reduction in wheel width), which is more or less exactly what it was.
Note: the Michelin-published 298mm section width was from 2015. The latest Michelin catalogs specify it as 295mm.
I fitted one of these used slicks to an 18x9 and 18x10 wheel to get some further section widths and ODs for fitment data:
  • 18x9, 266mm, 651mm OD - should have been 278mm/9" - actual is 12mm less!!!
  • 18x10, 281mm, 647mm OD - should have been 288mm/10" - actual is 7mm less!!!
And calculated values based on 9" and 10" measurements:
  • 18x9.5, ~274mm, ~649mm OD - should have been 283mm/9.5" - actual is ~9mm less!!!
And the custom wheel:
  • 18x10.25" 290mm, 645mm OD - should have been 290.5mm/10.25" - actual is exact!
So, either, the used slick had shrunk and its section width was less than expected on narrower wheels, OR, the slick is substantially narrower when fitted to much narrower wheels relative to the 11" measured wheel.
I've seen various dedicated M3 track cars on this forum use 18x10.5 et22 with wide slicks (for which the N2# would have ~293mm section width based on 2015 data, or ~290mm based on the 2020 data) but you'd be better off taking your own measurements to confirm fitment on your car.
Appreciate 3
BRMF821.00
David0ff1059.00
Kelse921131.50
      10-13-2020, 09:45 PM   #7
BRMF82
Australia
Drives: BMW M4
Based on the Michelin's advertised section width of 298mm on a measured 11" wheel, the section width should have been 290.5mm on the 10.25" wide wheel (i.e. 5mm less section width for each 0.5" reduction in wheel width), which is more or less exactly what it was.
  • 18x10.25" 290mm, 645mm OD - should have been 290.5mm/10.25" - actual is exact!!!
Hugely appreciated! Thank you very much.
      10-13-2020, 09:51 PM   #8
135
Australia
113
Drives: 135i
No problem at all.
Also, rather than importing wheels, have a look at Koya wheels as a local option. They provide semi-forged and forged wheels to a number of race teams and track cars and have several styles in 18" - the forged wheels can be custom made in any design.
BRMF821.00
      10-13-2020, 11:54 PM   #9
jacobe92
jacobe92's Avatar
I bought mine directly from Forgeline.
gum201250.50
      10-13-2020, 11:57 PM   #10
jacobe92
jacobe92's Avatar
It didn't clear the front. I had to put a 5mm spacer to clear it. Rear was good.
BRMF821.00
      11-14-2020, 07:42 PM   #11
135
Australia
113
Drives: 135i
An update to my post above...
I have just fitted some Michelin N2# 27/65/18 scrubs to 9.5" and 10" wide wheels.
The 10" fitment resulted in the same 281mm section width. The sidewalls are practically flush with the wheel's flange.
A 10" wide wheel is measured to the bead seats inside the wheel's flanges and the wheel is actually ~11" (279mm) wide to the outside of the flanges, which is what is measured to and what can potentially contact on suspension, or bodywork, if the tyre is undersized/stretched for the wheel - see my previous post for more discussion on this topic).
The 9.5" fitment resulted in a 273mm section width, which is only a minimal 1mm difference to my previously calculated value (based on the section widths of scrubs fitted to 9" and 10" wide wheels).
Actually, I rounded up my previous calculated value of 273.5mm to 274mm, so there really wasn't anything in it between the actual and calculated values.
So these are the second set of Michelin N2# scrubs that measure less than expected based on Michelin's advertised section width (both 2015 and 2017-2020).
The tread width of the Michelin N2# 27/65/18 is 252mm (2015) or 263mm (2017-2020), which seems quite narrow for such a wide section width (298mm in 2015, 295mm in 2017-2020) but, while it might be more commonplace with slicks, is more reasonable when in context of fitment to 9.5" and 10" wide wheels, tending to a more square-shouldered tyre, particular on a 9.5" wide wheel.
Interestingly, the tread width was 270mm in 2008 and 274mm in 2013, so it looks like Michelin has changed the specification on their slicks, as they would have through development over the years.
Note, Michelin (2019,2020) states the nominal wheel width for the N2# 27/65/18 is 11" +/-0.5".
Also, these scrubs weighed 9.8 kg (21.6 lbs).
      11-25-2020, 07:34 AM   #12
M2C AW
184
Drives: 2019 M2C Alpine White
I have a set of scrubs in these sizes going on..in SL9 compound...on a 10” square wheel set.
For those with experience....how much camber do they like ? What hot pressures ?
      11-25-2020, 08:59 AM   #13
135
Australia
113
Drives: 135i
The Michelin catalogue specifies various ranges for combinations of camber, minimum hot pressures and number of stints (races). It doesn't differentiate between front and rear.
Broadly speaking, camber -2° to -4° and min hot 29-33psi.
See page 52 for details to determine the minimum hot pressure for your target camber. Most likely the second table - the first table is specifically for TCR.
http://pneu-sport.cz/download/catalo...in-circuit.pdf
      11-25-2020, 09:15 AM   #14
M2C AW
184
Thank You !
Not sure tho how to interpret the 0, 1, and 2 values shown in the “mini hot pressures” table. That may take some research. Any insights ?
      11-26-2020, 01:14 AM   #15
135
Australia
113
Drives: 135i
The 0/1/2 numbers refer the number of stints (races), at the specified race length (e.g. 180 km), that can be performed on one set of tyres at the specified camber/pressure combination.
If your sessions are 10 laps at 2.5 km per lap, then you're only doing 25 km sessions, quite some way off the 180 km sessions/races they are designed for.
      11-26-2020, 09:51 AM   #16
CRRobert
55
Drives: 18 Avus Blue ZCP M3
Out of curiosity, where do people get the MICHELIN scrubs from?
      11-26-2020, 02:25 PM   #17
fanatic1
fanatic1's Avatar
Drives: 2019 M4 CS
2019 M4CS  [0.00]
Curious where are you sourced the studs (105mm?) and 25mm spacers?
      11-27-2020, 04:49 AM   #18
135
Australia
113
Drives: 135i
Being in the USA, you could try https://usedracingtires.com
      12-02-2020, 04:27 PM   #19
Kelse92
Drives: Former e92 M3 Owner
I get all my used slicks from local race teams I have connections with but there's a few online resellers out there too.
#ladydriven Heavy-spec M3 // KW Clubsports // AA x-pipe // Gintani muffler // Macht-Schnell intake // Gintani tune // OMP Seats // Too Many Apex Wheels // Stoptech ST-60 // Cobalt Friction brake pads
      12-04-2020, 09:58 AM   #20
Gomeler
500
H&R bolt-on spacers, OEM lug bolts clamping the tire to the spacer. Spacer came with bolts to secure it to the hub.
      12-04-2020, 12:56 PM   #21
fanatic1
fanatic1's Avatar
Drives: 2019 M4 CS
2019 M4CS  [0.00]
Saw those and wondered if they were safe for track use, but sounds like you’ve use them with no issue
f80post
