      10-05-2020, 05:11 PM   #1
jwirlatx
jwirlatx's Avatar
Drives: 2013 135i N55/E88 Convertible
Uneven wear on left rear (compared to right)
Have a left rear tire that may be wearing completely differently than the other rear. The reason I say "may" is because I didn't put them on. I thought they were all as new as what you see in the better tread picture when I bought the car. But, the right rear and fronts could have all been new with the left rear left undone. Doubtful. If they started out the same when I got the car, then it means something pretty egregious is going on as I haven't put 2K on it. Could that much damage be done in that few miles (2K)? I've spun them a couple times on start, but definitely the exception. It's even wear across the tire (not like the inside wear in camber situations). Any thoughts?
Thank you for any suggestions.
      10-05-2020, 08:15 PM   #2
NorthernDancer
851
Drives: 08 Sedona 128 & 06 330xiT 6MT
Do the 2 rears have the same date code? What are the last 4 numbers of the DOT code? These numbers are only on 1 side of the tire.
      10-07-2020, 12:59 PM   #3
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
Could maybe have a Toe problem somewhere? Maybe try to take it to one of those tire places that advertise a free alignment check.
Or a reputable alignment place might charge anywhere from $20 to $40 to check it.
Depends on who you want to trust more I guess
