09-30-2020, 08:32 PM | #1 |
3992
Rep 3,411
Roastbeef sensei
Well, I thought I lightened her up a bit, but just got corner balanced... She's 3,608 lbs wet
Primary weight reduction efforts: Titan 18" 9.5/10.5 ST 60/40 BBK MFactory carbon drive shaft Sparco seats, BK mounts Removed rear seats top/buttons JRZ Coilovers Titanium xpipe Weight gain culprits: Harrop SC 275/305 NT01 BK harness bar Sunroof (going to swap with carbon) Do99 oil cooler (increased capacity to 10 liters) Full tank of gas Roast B, are you accepting any new applicants into your weight watchers program? I'd like to drop ~ 150-200lbs. While I could drop the SC, that's no fun as I'm not building for a race class. But I would like to compete in TT and time attack events as I continue to progress. Winter Plans: - Strip interior from seats back - remove sunroof glass and mechanism (BW carbon replacement) - lighter battery - radio /speaker delete - remove doorcards, replace hard sport ltw cards - wiper fluid delete - 50/50 on AC delete and in conjunction go with electric steering pump (delete intercooler, reservoir). This might be extreme for a dual duty car although I don't need to drive it around town. Just choose to in the summers and love to sweat with windows down. + jp Marketing half cage + 65-68" wing, 12" risers, lip + brake ducting
Not a Doctor, those are just my initials.
09-30-2020, 09:06 PM | #3 |
3992
Rep 3,411
Yeah, I'll be doing that program as well.
10-01-2020, 11:30 AM | #5 |
1132
Rep 1,366
I have a DCT/Sunroof car and was trying to figure out how you are 50lbs heavier than me and its definitely that S/C.
Drop your battery to an antigravity. It's pricey but you'll save 30lbs easily there. Carbon roof replacement would also be awesome. I would think with your list there you might be able to get down another 150 like your goal. Also, maybe consider pulling your dash and swapping to a single hump dash and removing all the nav stuff? Unless your car was optioned already without one
#ladydriven Heavy-spec M3 // KW Clubsports // AA x-pipe // Gintani muffler // Macht-Schnell intake // Gintani tune // OMP Seats // Too Many Apex Wheels // Stoptech ST-60 // Cobalt Friction brake pads |
DRLane3991.50 |
10-01-2020, 11:45 AM | #6 | |
3992
Rep 3,411
I would probably leave the dash piece, maybe fill the hole with gauges or something. But I would absolutely strip out the nav screen etc. Its 2008 tech and its garbage. Don't care about MDM, as the only setting I use is DCS off.
Kelse921131.50 |
10-01-2020, 01:02 PM | #7 |
Stop the hate, get a V8
3851
Rep 8,625
Roastbeef-san is the correct vernacular, I think.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
10-01-2020, 01:04 PM | #8 |
3992
Rep 3,411
As a peer yes, but I'm intending to be respectful of our weight reduction teacher... 😬
10-01-2020, 03:30 PM | #9 |
746
Rep 1,848
My E46M3 weighs 3060 with me and a full tank of gas. What would I be called?
CorruptCommie345.50 |
10-01-2020, 03:31 PM | #10 |
3992
Rep 3,411
Dancing with the devil wearing the wrong chassis!
10-01-2020, 03:33 PM | #11 |
3992
Rep 3,411
Or more accurately, passing by...
10-01-2020, 08:19 PM | #12 |
11586
Rep 12,730
hehe, i didn't invent this madness, i simply learned and was influenced by others on this forum. slicer has been a big help and a huge influence, and he has shown me a few tips and tricks and has been very helpful.
i'll post a few ideas a little later tonight when i have some time.
Instagram; @roastbeefmike
slicer2742.50 |
10-02-2020, 05:32 AM | #15 |
1074
Rep 1,025
I'd like to report shots fired
Stock seats too I believe. I'd truly love to see what my own car weighs as it's my ultimate goal to get near 200lbs out of the car. I know I'm down at least 100lbs right now but I don't have a baseline.
Steve::::2012 AW E92::::IG - @sjs0433
roastbeef11586.00 |
10-02-2020, 12:35 PM | #16 |
11586
Rep 12,730
DRLane i'll share a few ideas beyond the basics you already mentioned.
since you'll be using a 1/2 cage, i presume carbon doors are off the table. you can still take 3lbs out of the doors without reducing safety by losing the insulation and trimming some excess metal. another silly thing i've fantasized about is moving the driver's side door controller to the center console. this moves weight more inboard, potentially allows for less wires, and you get to ditch the passenger side window controller completely. replace the rear window and rear quarters with lexan. i wouldn't touch the front windscreen for safety, and leave the sides alone, because they would have to be fixed. https://www.plastics4performance.com...=126&model=191 move the lightweight battery to behind the passenger seat on the floor, and shorten the battery cable. titanium nuts and bolts where applicable (its not cost effective, but none of this is). scrape off all the adhesive sound deadening bonded to the body. trim all interior tabs that are no longer used. get rid of your hood and trunk hinges and the struts associated with them. use aerocatch latches instead. a pair of trunk struts weigh about a pound. the hinges weigh about 1.5 pounds each! drill out the front radiator support. it looks like its plastic, but it has a metal core. get rid of the windshield washer assembly, or run one wiper. (i'm currently working on lightening mine, its a long term project). thin out the wiring harnesses to only keep what is necessary. if you have a really lightweight exhaust, you don't need the side rear exhaust mounts. they weigh about 2.4 lbs. burger tuning cowl filters. what did i miss?
Kelse921131.50 |
10-02-2020, 12:53 PM | #17 |
2760
Rep 5,483
Short of just removing parts, the battery is order of magnitude better bang for buck lightweighting than just about anything else. I, personally, wouldn't go to the trouble of moving it behind the back seat, but I bet there's a couple lb in the wiring there too. But 8lb of lifepo, and a few morelb of wire, low to the ground over the right rear isn't a terrible place for weight.
Don't delete the AC, driver comfort is a performance issue, if you're sweating in grid for 10 minutes ebfoer you go out you're not going to be as sharp. Delete it when it breaks, and install a cool shirt system. Also swass sucks. Second the burger tuning filters. HAve had them on my almost all-street car for a couple years now and no adverse effects. Center console - you can lightweight this with the sunglass tray instead of the ashtray, saves 97 grams! There is a nice Android-based thing that can use the stock dash hump screen for lots of cool programs including Torque and the like. Might want to look into those before you bin it. But don't listen to me my E90M is 3480 with a full tank and full stock interior still, bleh, pig, lol Also, what's a Do99 oil cooler, is that like turning your oil cooler up by 11?
10-02-2020, 01:08 PM | #18 |
1074
Rep 1,025
A few more easy targets....
Between the body and trunk lining there is more sound deadening. Rear seat head rests Rear floor mats (or all if you're really hardcore)
10-02-2020, 01:20 PM | #19 |
11586
Rep 12,730
10-02-2020, 02:06 PM | #20 |
11586
Rep 12,730
those are all "givens" sir.
10-02-2020, 03:20 PM | #21 | |
3992
Rep 3,411
