09-17-2020, 06:43 PM | #1 |
90
Rep 254
seat back sticker
i need something to stick to the back of the passenger side seat so a suction cup will stick to it. i'm looking for something that will stick but not leave a residue when i remove it. suggestions?
TIA
- End of Line
09-17-2020, 07:00 PM | #2 | |
18708
Rep 14,115
Drives: G82 M4C X-Drive
https://www.amazon.com/BOPai-Circula...D26ZWPA0ZE0KE3
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
09-20-2020, 11:31 AM | #4 |
18708
Rep 14,115
Which mount did you use? My gopro branded one doesn't stick.
09-20-2020, 07:18 PM | #6 |
90
Rep 254
ty for the link suggestion above. the disc was a little small for my ram mount suction cup (~3.3") but i used the 3M VHB adhesive name and found a 3.5" disc on ebay. i'm going to give that a try and see how it goes.
i had the same result without any sticker. the ram mount would "stick" but eventually let go. it stays on the windshield forever. my concern would be it decided to let go in a turn and flies out the window. 3m says the adhesive will come off with no residue but i'm ok if it takes some effort to get off. it'll be on the back of a seat and that's not an area that concerns me greatly.
- End of Line
09-22-2020, 12:52 PM | #7 |
1107
Rep 1,301
I just bought this one, and yesterday it held up just fine for 6 sessions at NJMP with a Fat Gecko 3.5" suction mount
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 It uses 3M VHB adhesive, so may leave some residue when you remove but presumably that can be dealt with with adhesive removers When you apply, be sure to hold strong pressure for at least a minute to get it to adhere properly |
jmg18708.00 MyFragileHalogen449.50 |
09-27-2020, 03:02 PM | #8 |
90
Rep 254
update.
the last poster and myself went down the same path so that seems like the success route. here's the one i used - NAVISAFE 3M VHB 3.5" self-Adhesive mounting pad (2/Pack) for Suction Cup https://www.amazon.com/dp/B085T4HZWZ..._45oCFb7DVA8GS it's meant for navigation lights but fits the suction mount for a ram suction cup perfectly. it's clear so you'll see the seat underneath. it's not perfectly transparent so if you're looking for 100% you jay want to try the other one first. very thing so except for the slight differences where the air trapped it's pretty inconspicuous. the spot mount spot gives a good view of my head, hands, and windshield. bonus a power hardware doesn't get in the way either. apex pro mounts on the bottom left of the windshield and i'm in business.
- End of Line
jmg18708.00 |
