09-01-2020, 07:00 PM | #1 |
617
Rep 600
Requesting low fuel pressure sensor replacement guide
An electrical wiring check tutorial would also be greatly appreciated.
This request is to address a persistent fault code 119202 (Fuel pressure sensor; electrical: Short to ground) which has come on everyday for 3-months now. I notice the S55's layout underneath the air-to-water intercooler is very similar to that of the N55 (recently did a HPFP upgrade on that motor) but not sure if a coolant flush is necessary or not. And also presume the coolant reservoir for the intercooler is separate from regular coolant reservoir for the engine. Thank you in advance!
09-02-2020, 06:46 PM | #2 |
252
Rep 631
Drives: 2014 M6 Grand Coupe CP
There is information available from NEW TIS. The link below gives information on the low pressure sensor (which are in one unit).
https://www.newtis.info/tisv2/a/en/f...sensor/XS5Pcgs See if you can get the information here https://www.newtis.info/tisv2/a/en/f...ressure+sensor good luck
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
09-30-2020, 04:52 PM | #3 |
617
Rep 600
Replaced the sensor. Really painful to get to but solved the issue once and for all.
11-22-2020, 09:51 AM | #4 |
8
Rep 39
06-28-2021, 05:32 PM | #5 |
Rep 10
Any uodate on this? Trying to install the lpfp sensor. Looks like its not working after installing the after market lpfp. Decided to switch back to stock but still no luck. Thanks
02-10-2022, 06:26 PM | #7 |
617
Rep 600
You will need to remove everything down to the intake manifold in order to access the low pressure fuel sensor. So imagine doing spark plugs on the S55 + top mount water intercooler removal + intake manifold removal. Then of course, reassembly.
08-07-2023, 04:20 AM | #9 |
617
Rep 600
As previously mentioned above, you will have to remove everything in the engine bay all the way down to the intake manifold to reach the HPFP.
