08-23-2020, 12:03 PM | #1 |
86
Rep 102
Need help - car not moving making crackling sound
Hi guys,
Last night I took off at a traffic light and I heard a bang and the car lost power and it started to make crackling sound as if it was coming from the rear wheels and something was turning. When I put the car in neutral the sound stops. However the sound comes again when the car is in drive or reverse and it's undriveable. It feels like that the connection to turn the wheels broke. Got it towed to a local Indy shop in Northern Virginia. On the right wheel (passenger-side) there is a splash of grease as you can see in the pictures. There is no grease on the left (driver side) wheel. There was also no leakage of oil which tells me that there is nothing wrong with the differential. Any idea what broke and what type of cost am I looking at? The car is out of warranty. |
08-23-2020, 12:45 PM | #2 | |
Rep 18
aliusa86.00 |
08-23-2020, 09:06 PM | #4 | ||
86
Rep 102
08-24-2020, 06:55 AM | #6 |
252
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
Definitely looks like a broken axle and your description confirms it. Shouldn't be too costly to repair. You can find used axles pretty easily as well.
Good luck |
aliusa86.00 |
08-24-2020, 08:42 AM | #7 | |
Rep 18
Apparently they're prone to cracking over time, and I'm sure launches don't help. Best of luck! |
aliusa86.00 |
08-24-2020, 10:57 PM | #8 |
42
Rep 101
Yep absolutely, I bought an axle off a total loss 2013 m5 with 15k miles for $275 delivered. If it’s an option DIY it. My quote for the axle shaft and hub bearing assembly was over $4k from the dealer. I did it in about 4 hours with some help and the total cost was $700 with everything including an OE hub assembly. Whatever you do, make sure the axle compression bolt is replaced and properly torqued down. That one nut holds everything together.
aliusa86.00 |
