08-22-2020, 09:34 PM | #1 |
Rep 26
Drives: 2015 BMW M4
ECU Updated - Front Turn Signals not working and SRS light flashing
Hello All,
I was hoping someone could help me as I have now spent two days trying to figure out this issue. I have a 2015 F82. I used ESYS and the TAL CALC/PROCESS procedure following this guide. Shipment I-Step version is F020-14-11-505. I see two for Target I-Step. F020-20-07-530 and F020-07-540. I chose the 540 version. I did the TAL calculation with the 'Include ECUs from SVT' and then proceeded to TAL Processing to start the upgrade. With Shawn's help, I was able to get them all updated, but I have an error on the dash that says the front left and right signals are malfunctioning and front blinkers do not work while rears fast blink. I also have the airbag light flashing on the dash. Has anyone experienced this? If so, can anyone give any input on how to fix it? I tried clearing codes in Transmitter, but to know avail. Thanks in advance. Travis T |
08-23-2020, 04:28 AM | #2 | |
BimmerPost Supporting Vendor
1790
Rep 3,056
Get ISTA and check those faults. Thanks
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
08-23-2020, 10:07 AM | #3 |
Luxury at the redline :)
9105
Rep 7,563
Code out the warm and cold bulb checks for the turn signals, to eliminate the hyper-flashing..
As far as the air bag error, make sure the right region variant is set; US-spec vehicle programming requires it to be coded for a "dual stage" air bags, the ROW is a single stage.. |
08-23-2020, 10:23 AM | #4 | |
1790
Rep 3,056
08-23-2020, 01:01 PM | #5 | |
Rep 26
Drives: 2015 BMW M4
08-24-2020, 05:19 PM | #6 |
163
Rep 387
After updating the car, I had to do some headlight learning procedure, window learning procedures and some other things in ISTA. You just need a copy of ISTA that is new enough to support your car/software level. There were also like 100 faults stored, but most of those cleared before doing those things.
You shouldn't need to be doing any coding. My bet is you just need to clear the faults, then go through the recurring faults and run the ISTA procedures to initialize/learn those modules. |
08-24-2020, 06:03 PM | #7 | |
Rep 26
Drives: 2015 BMW M4
08-24-2020, 09:14 PM | #8 | ||
9105
Rep 7,563
I use the Bimmercode APP to remove the bulb checks (see below) As far as the variant region spec, that can only be done on ESYS but requires someone who's familiar with the process. I'm sorry, It's foreign to me 🤷🏻 https://apps.apple.com/us/app/bimmer...i/id1130787459 |
