08-05-2020, 06:28 PM | #1 |
33
Rep 101
Feeler: BBS BMW F87 M2 CI-R Wheel Set 19x9.5 19x10.5
Hello, Looking to potentially sell a near new set of BBS BMW F87 M2 CI-R Wheel Set (19-inch Tuner Fitment). The naked wheels are over $2,700 on TireRack and $2,660 from iND. They are MINT, still look new, and only used on a weekend car for less than a year. They come in the original boxes with no tires, no TPMS. Front: Size: 19 x 9.5" Center Bore: PFS ET: 25 Bolt Circle: 5 - 120 Weight: 26.00 lbs Hardware Kit: 09.30.368 Rear: Size: 19 x 10.5" Center Bore: PFS ET: 35 Bolt Circle: 5 - 120 Weight: 25.80 lbs Hardware Kit: 09.30.368 UNCOMPROMISING, AESTHETIC AND TRENDY The concave high-performance wheel in the distinctive Y-spoke design is absolute weight optimized. Performance Line: Flow forming uses hydraulic rollers to achieve greater density in the material structure for the rims of our light alloy wheels. The rim well of the over 300 to 350 degree centigrade hot wheel blank is kept in a continuous rotational motion under high pressure and at high temperatures, and subsequently rolled out over a cylinder in one work step. The equipment functions according to the principle of a potter's wheel to remodel the wheel blank. The desired result: a thinner wall thickness of the original rim and therefore a lighter weight wheel. In addition it provides optimally dense material structure and greater material strength. Forging Technology: Forging is a non-cutting forming process for material in a heated, solid condition. In order to generate the highest degree of material density and weight reduction at top performance from our high-strength and durable aluminum or magnesium alloys, they are further enhanced in a complex forging process. This entails placing the heated star hub or the entire wheel blank in a press and compressing it in several work steps at 5000 to 8000 tons of closing pressure to further densify the material in a special form known as a matrix. In between the individual work steps, the blank is repeatedly heated to approx. 400 degrees centigrade. As a result an optimal material structure is achieved particularly at the areas of high strain, the wheel can be dimensioned smaller, and is thereby lighter in weight. Fitment Notes: "Tuner" fitment: This will have a more aggressive look. The "Track" is increased and the tire/wheel is out to the edge of the fender. This may require some vehicle modification such as fender lip rolling, to create the proper tire to fender clearance. May require slight modification including, but not limited to, rolling of fender/lip. (The tire section width and alignment settings are also important factors.) Special Features: The wheel captivates not only visually with its distinctive, BBS typical Y-spokes, but is also equipped with all kinds of technical finesse. Weight optimization here is top priority. Thanks to the proven Flow-Forming technology and back-milled spokes, the CI-R is an absolute lightweight construction wheel with replaceable stainless-steel rim protector. Last edited by 911TT; 08-06-2020 at 09:55 PM.. |
08-06-2020, 06:32 PM | #3 |
33
Rep 101
