M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      08-05-2020, 07:53 AM   #1
b21playa
30
Drives: LCI e60 535d msport
Water in left boot well
Hi all
Today the sound stopped working in my f10, removed left hand boot trim to find water in there. Not sure where it’s come from but possibly fried the amp
Is there supposed to be a drain hole there, is this a common issue or have I just been unlucky?
Thanks
      08-06-2020, 04:40 AM   #2
Craze
161
Drives: M5 E60, M5 F10, X5 50i
I had this issue
There is a plastic piece that sits over each tail light
The round socket when water comes down leaks water
It comes from factory with foam under it
I had to silicon mine in and no leaks
      08-06-2020, 04:43 AM   #3
b21playa
30
Originally Posted by Craze View Post
I had this issue
Hi
Thanks for that, any pictures by any chance?
Want to make sure water doesn’t come in again as I’ve ordered any amp which isn’t that commonly available
      08-06-2020, 06:46 AM   #4
b21playa
30
Think I've found the leak. Took off the drip trim and low and behold there was a clear hole in the boot. the plastic grommet fixing which sits in the bodywork was missing, the other side is present. Stripped out all boot carpet and could see water has trickled down into battery well but it wasn't deep. I'll have to remove everything to clean it all up properly.
I've ordered new ones which I'll silicone in before fitting the new amp
Thanks for the suggestion
