      07-30-2020, 06:35 AM   #1
StarThreat
7
Drives: N54 E82
Hello fellow 1 series owners.
I have an E82 and I am looking for some advice on if anyone ran spacers on OEM 18" wheels - factory sport suspension.
It has 78k miles on it, may be a bit older and sag just a little bit but I'm not entirely sure. No leaking from suspension components.
I was thinking of running:
Front: 12mm hubcentric - 225/40/18 - firehawk indy 500 - 7.5 inch wheel - offset: +49
Rear: 10mm hubcentric - 255/35/18 - firehawk indy 500 - 8.5 inch wheel - offset: +52
Tires are brand new haven't been mounted yet.
I did a couple searches on various forums, including this one, and some say rears will rub on dips and some say there's no rubbing at all. Some members have had their cars lowered also so I don't know if their results will be accurate in terms of my car.
I plan on getting an alignment when I get the tires installed, will alignment shops be able to adjust suspension settings to stop rubbing? Will they be able to see if it rubs before the car is taken off the alignment machine? Ideally I wouldn't want too much adjustment, I would like for the best even tire wear and still maintain proper handling.
Anyone know if I have anything to worry with this setup or should I just garbage the spacers and run it as is?
Thanks ahead of time!
      07-30-2020, 07:03 PM   #2
instroke
19
Drives: Alpine white 135i coupe
I ran 12 mm in the back and 10 up front. Spacers do enhance the look so much. With Stock suspension you will have nothing to worry about. Best of lucks with your mods...
      07-31-2020, 05:44 AM   #3
StarThreat
7
Drives: N54 E82
Thanks for your response! Did you have this wheel and tire setup as well?
      07-31-2020, 08:46 PM   #4
instroke
19
I have BMW 261 wheels mounted on cheap summers same 255/35 rears and 225/40 fronts. I am lowered on Swifts and ever since lowered, I have negative camber, the handling is way better, and I know I am wearing the insides of my tires out. But don't care with the current tires I have. Every tire will have a different amount of bulge on our rims. But again the 10mm/12mm spacers you have ordered shouldn't give you any rubbing, as you are also at stock height. Hope this helps - cheers
2013 N55 135i
- BMS intake - Arm 5" I/C - VRSF charge pipe - 1 step colder plugs- JB4/MHD - VRSF downpipe- Berk mids
- Agency axleback- Swift springs
      08-01-2020, 08:08 AM   #5
asbrr
545
Drives: 2014 335ix M-Sport
Hey StarThreat so I have the Indy 500s but in 215/245 size now and 10mm in the rear, 12mm in the front spacers on factory 18". As per my reply in the other thread, you will probably get some rub on dips in the rear. See my response:
https://www.1addicts.com/forums/show....php?t=1271577
      12-12-2020, 11:50 AM   #6
PcarDefector
65
Drives: 135i DCT+PS+PE / X3 M40i Stock
No rubbing with 12.5mm spacers and 13mm drop with factory Msport option 18" wheels and tires.
Last edited by PcarDefector; 12-29-2020 at 11:04 AM.. Reason: updated size of spacer
      01-14-2021, 11:35 AM   #7
Cbadca
Drives: BMW 135i
I have indy firehawks 225/40 and 255/35. had them on stock msport suspension with stock style 261 wheels and now with wider apex arc-8 wheels with lowered suspension (-2 camber) no spacers & no clearance issues either set up. when i wear them out i'm going up a size again to 235/265.
      04-07-2021, 11:58 AM   #8
Luftmeister
Office Linebacker
Drives: 135i
Exact same here. Awesome tire for the price.
      04-09-2021, 08:48 AM   #9
Luftmeister
Office Linebacker
Drives: 135i
What are the offsets of your new Apex's?
      04-09-2021, 09:16 PM   #10
Petro135
Drives: 2008 135i E88
2008 BMW 135i  [0.00]
I got no spacers and same 225/40 and 255/35 and stock suspension which is pretty new and not sagging yet. And i get rub on bigger dips. Im waiting to roll and push fenders. But im giving it a little more time until i need to get coilovers
      04-10-2021, 08:36 PM   #11
asbrr
545
Really?? This is really surprising. For stock suspension, 225/255 has a lot of room. Are you running R-comps or some tire that's ultra wide compared to others..or ones that have a very square shoulder....
      04-13-2021, 08:49 PM   #12
carscatscoffee15
carscatscoffee15's Avatar
Drives: BMW 128i ZED Package
good to know.. I'm thinking about sizing up the meats as well
225/40/18 fronts (from 215)
255/35/18 rear (from 245)
so is there rub or no rub? depends on the vehicle? I'm on stock suspension with 28k miles. would i even need the spacers? i mean OP has the exact same set up as I do.. who knows if he still has the vehicle? (just minus the spacers)
any input?
Mods Done: AA Exhaust/Headers | 3SIM | MILVs | StageFP Dyno Tuned | Euro Box Intake Swap | LCI Blackline Tailights | OEM Euro Bi-Xenon Swap from Halogen | Rear Bumper M-Sport Swap | Rear PDC Retrofit | BMW OEM CF Diffuser/Spoiler | BMW Front Aero Kit | Supersprint Sec 1 Cat Delete Straight Pipes
To Do: Ohlins R n T Suspension | Front/Rear Sway Bars | M3 Front Control Arms/Bushings
Eventually: AT -> MT Swap (!?)
      04-14-2021, 02:10 PM   #13
asbrr
545
any input?
No definitely no need for spacers! That is actually what might cause you to rub, the usual rub spots on the outside by the bumper tabs (front or rear). If you skip the spacers and have normal tires not some ultra wide r-Comps, you should be able to fit 225/255 with no issues (assuming stock wheels and offsets).
      04-14-2021, 03:20 PM   #14
carscatscoffee15
any input?
nah I was thinking of getting Conti's DWS06 Plus or the Michelin Pilot Sport AS4's
everything's stock for now but won't be when i do the suspension after the tires. ET49 in the front, ET52 in the back
thanks for the response!
asbrr544.50
      05-08-2021, 11:21 PM   #15
PcarDefector
65
With the factory offsets, slightly wider tires and < 1" lowering, you should be able to use 7mm spacers. OEM 1 series wheels have too much offset and look much better with spacers.
I'm using 18" stock rims and stock tire sizes with Turner MS 12.5mm spacers.I also have the BMW PSS so it's about 1/2" lower than Msport or about 1" lower than non-sport cars.
      05-12-2021, 03:11 PM   #16
smi2710
11
Drives: 2006 bmw 325xi
i am running 225 front and 255 rear indy fire hawks on stock 18's with a 15mm front spacer and 12mm rear lowered on a bilstein b14 setup with no issues of rubbing at all.
Appreciate 2
