07-20-2020, 01:23 AM | #1 |
293
Rep 624
Adding homelink
My M3 doesn’t have the homelink rear view mirror. I seen a couple on eBay. Do you think that it’s just a matter of replacing the rear view mirror for one with the garage door opener buttons on it, and then having it coded? Anyone done this before?
07-21-2020, 10:01 AM | #2 |
3274
Rep 6,723
I remember doing similar in e46 but Homelink was not in rear view mirror.
I believe all of the Homelink hardware is inside the mirror unit and is plug and play. No VO coding should be needed. I’ve never seen VO code for Homelink. |
07-21-2020, 10:08 AM | #3 |
1234
Rep 1,164
Just double check if the plug for the mirror is tucked away behind your headliner first. if so, then it should just be a simple plug & play. like a previous poster stated, all hardware is within the mirror itself and doesn't require coding.
07-21-2020, 10:41 AM | #4 |
3274
Rep 6,723
And just in case, here’s a good DIY to get to the wiring behind headliner/light assembly
https://f80.bimmerpost.com/forums/sh....php?t=1026319 |
07-21-2020, 03:58 PM | #5 | |
82
Rep 283
Have you thought about replacing your garage door motor? They now all pretty much come WIFI enabled which allows you to open/close with their app. Might be easier going this route? just a thought... its only about $200 for a new garage door motor.. |
tom @ eas8210.50 |
07-21-2020, 04:15 PM | #6 |
BimmerPost Supporting Vendor
8211
Rep 18,823
Drives: BMW
Or for even cheaper, add Wifi to your existing door opener:
https://www.amazon.com/Smart-Garage-.../dp/B075H7Z5L8
07-21-2020, 04:17 PM | #7 | |
82
Rep 283
07-21-2020, 04:42 PM | #8 |
1234
Rep 1,164
FYI - you can also program your valve controller to the homelink, which is the only reason I use it. Amazing and no need to fiddle with the stalk, bm3, or some key fob.
