BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      09-24-2008, 10:48 PM   #1
varun
27
Drives: '14 550i M-sport
Track wheel/tire setup on E90 M3
Im looking at a pair of ASA JH8 wheels that were off an E46 M3. I know the fronts will fit the E90 with spacers but is this a safe setup for the track. Does it affect the handling in a negative way? The E90 appears to require an offset of +15 but the E46 was +40. I guess a 2mm spacer would do it?
The wheel I am looking at is:
ASA JH8 18x8.5
Offset: 40mm
Backspacing: 6.38"
Bolt Pattern: 5-120
Rec. Tire Size: 245/35-19
Weight: 24.6lbs.
How are these ASA wheels? Heavy?
      09-25-2008, 12:26 AM   #2
JAJ
80
Drives: 2014 Shelby GT500
ASA JH8 18x8.5
Offset: 40mm
Backspacing: 6.38"
Bolt Pattern: 5-120
Weight: 24.6lbs.
Your numbers seem a little jumbled.
For the fronts you need a 10mm spacer (and 35mm bolts) to get the offset down from 40mm to 30mm - the stock is 29mm, so nobody will notice the missing 1mm.
For the rears, well - it's not clear what rears you want to run.
The front tire for the 18x8.5" rim is 245/40x18 (not the 19 fitment you listed).
m3post
