06-30-2020, 08:04 PM | #1 |
67
Rep 129
What are some of the most popular things people code?
Is there a list of popular/recommended coding to do? Going to have some done soon and want to knock it ll out now. I did a search and couldn't find a thread of recommendations sorry.
06-30-2020, 08:07 PM | #2 |
1234
Rep 1,164
07-01-2020, 07:58 AM | #3 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
This is what I code on both of my BMWs:
Remove iDrive warning Remove analog & digital speedometer 3mph "correction" ASD off Doors unlock at engine shutdown Driver door open turns off all electronics
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
07-01-2020, 11:44 AM | #4 |
298
Rep 584
I remember that in previous models the correction would only apply to the speedometer but not the cruise control, is that still the case? As in if you removed that "correction" you'd show 70 mph but if you set the cruise control it would say 73 mph.
07-02-2020, 07:19 AM | #7 |
1837
Rep 6,990
Nope - it removes that "correction" factor, and when you set the cruise for 70, it reads 70.
Tangent297.50 |
07-02-2020, 07:22 AM | #8 |
1837
Rep 6,990
Can't help you there...I use Carly. The basic premise is to disable this function in the appropriate module.
07-02-2020, 12:03 PM | #9 |
246
Rep 513
I know the digital speedo is a easy fix, did it correct the analog, physical speedo too?
07-14-2020, 11:43 AM | #10 |
298
Rep 584
Coded the option and found that there is in fact a discrepancy between the speedo and cruise display but it's only 1 mph. With the HUD showing 70, turning on cruise control shows a set speed of 71. Since it only shows up briefly anyway I can live with that.
07-14-2020, 02:49 PM | #11 |
779
Rep 1,636
07-15-2020, 07:56 AM | #12 |
1837
Rep 6,990
As far as I recall, there wasn't a separate option to enable/disable the correction on the analog speedometer. It is no longer present on both instruments.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey Last edited by RoundelM3; 07-16-2020 at 07:40 AM.. |
07-16-2020, 07:39 AM | #13 |
1837
Rep 6,990
Yeah, I noticed that too - not sure what that's all about.
08-10-2020, 05:55 AM | #15 |
9
Rep 55
I did a fair bit on mine,
Mirror fold Start stop engine last memory Air Conditioning off on Auto iDrive off on door open Mirror fold speed max (50Km/H) Mirror angle on reverse |
