06-21-2020, 02:03 PM | #1 |
765
Rep 554
Need location of the "Fuel Pressure Sensor" not "Low"
Can someone show me exactly where the fuel pressure sensor is located in our cars (One on right)? I have replaced the low pressure, the one on the left, it's right under the driver's side strut brace.
Daily: 2010 Venza
Grocery Getter: 16 Q50 Red Sport Track: Top Gear or Grand Tour Concealed Weapon: 11 BMW e92 M3 DCT ESS G1 |
06-21-2020, 02:06 PM | #2 |
64
Rep 258
that one on the right looks like a high pressure sensor, for direct injection vehicles. As far as i know we don't have that type sensor since we have traditional fuel systems. Are you sure that's for an s65 M3 and not a 335i?
06-21-2020, 03:05 PM | #3 | |
765
Rep 554
OEM Bosch Fuel Pressure Sensor - N54 N55 N63 S55 S63 S65 Bosch T#: 399809 | Part#: 13537622231
Daily: 2010 Venza
06-21-2020, 03:50 PM | #4 |
11503
Rep 1,067
The one on the left is the original style sensor. The one on the right supersedes it, but requires an adapter and o-ring. This is the only sensor on the S65, the one behind the airbox on the fuel line. There is no second fuel pressure sensor.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus |
Scharbag2631.00 deansbimmer3752.00 |
06-22-2020, 01:27 AM | #5 |
BimmerPost Supporting Vendor
3387
Rep 7,542
Same sensor. The silver one is simply the newer style. They are both low pressure and normally see between 2 and 6.5 bar. High pressure sensors see upwards of 200bar but are only on factory boosted applications.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
deansbimmer3752.00 Dpc2u11503.00 |
06-22-2020, 04:08 PM | #6 | |
2631
Rep 2,141
Drives: 2011 E92 M3
I installed the new style directly into the fuel rail with the O-Ring and is seems to work just fine without needing the adapter. I have the little spacer but I could not see any reason for it to be installed. Semms to me it would just elevate the fuel sensor higher. Anyone know why the little spacer needs to be there? Am I going to run into an issue by not installing it? Cheers,
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
Dpc2u11503.00 |
06-22-2020, 08:06 PM | #7 | ||
11503
Rep 1,067
