06-20-2020, 04:16 PM | #1 |
Rep 19
HELP ! Anyone tried to code their car for different region? And lots to go with
Hi all,
I just bought a 2015 Pre LCI F80 M3 , its import from Japan so the car come with japanese menu + japan NAVI but now the car is in Hong Kong. So there is some problem for me and i hope i can find some answer here. 1: Coding/Upgrading Car Firmware which it should be in HongKong , showing my language and my goal was to have latest Hong Kong Map in my NAVI and have the right frequency for Radio (Hong Kong have wider frequency then Japan). 2: Coding Headlight from 2015Pre LCI Full Adaptive to 2018+ Standard LED( which dont have Adaptive Function. 3: Coding 2018+ M3 CS Tailight with OEM retrofit harness. 4: Coding Front seat Airbag delete since i am doing front seat change. 5: What else you guys suggest for me to code the car at the same time since my car was a 2015model? Any hidden function can be brought out? I want to make the car system as up to date as possible. So far it's what i needed at the moment, but i am completely new into BMW coding , i try to search Bimmercode if it can do the work for me because its user friendly but seems cannot satisfy what i want, tried look into E sys also but seems its a lot more complicated, So i want to have more advice from you guys what should i do and whats the best way to do the job? Looking forward from you guys, greatly appreciate. Thankyou |
06-20-2020, 04:28 PM | #2 | |
BimmerPost Supporting Vendor
1790
Rep 3,056
Thanks
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
06-20-2020, 04:32 PM | #3 | |
Rep 19
How should i start? i even cannot find where to download the software it and use what cable to do the work. And before i start to play with E sys should i use ISTA+ to do any update first? Thankyou!! |
06-23-2020, 02:21 PM | #6 |
Rep 19
